Author Topic: So ... 3d Printers....  (Read 446942 times)
  • Last login:February 15, 2025, 12:57:26 pm
  • Bitches love Centipede
Re: So ... 3d Printers....
« Reply #680 on: March 20, 2018, 10:17:05 am »
Cash in hand for a dickbutt cookie cutter.  Not even joking.
Use that cash to get to Zapcon, and you get one for free...  :P
%Bartop
« Reply #681 on: March 20, 2018, 11:12:56 am »
All this because I drew a dickbutt on Paul's poster 2 years ago.
  • Last login:Today at 01:43:48 am
« Reply #682 on: March 20, 2018, 11:27:58 am »
Made this for my homie JulesWallet
« Reply #683 on: March 20, 2018, 11:28:25 am »
Tirekickers gotta tirekick
Titchgamer
« Reply #684 on: March 30, 2018, 11:33:41 am »
Ive been a busy 3D printing elf!
So firstly I designed my first 3D model, a charging dock for a PSP and printed that:
I also printed this as a surprise for the Ms, is a wedding cake topper :p
Also I have just finished printing a fully articulated metal gear rex.
Ile get some pics up once its painted but that may be a while yet as theres lots of pieces!!
When I was printing Rex one of my box fans started getting noisy so I have ordered some new silent fans for that.
Fitted one but gotta wait a week for the other :(
I also fitted dampers to the X & Y steppers during the down time to help quieten it a bit and a new metal extruder.
And finally just because You always want to see finished pieces heres one I finished earlier:
So what you guys been making?
Slippyblade
« Reply #685 on: March 30, 2018, 12:11:21 pm »
Did you acetone smooth that PSP dock?  That looks great.
  • Last login:Yesterday at 12:17:00 am
« Reply #686 on: March 30, 2018, 01:36:40 pm »
Yeah I'd appreciate some more info.... finish looks top-notch.  Also do you have a link to that extruder?  I don't know if it's the humidity or what, but my filament has broke off while not in use 5 times this month.... I'm getting sick of taking the dang thing apart.
05SRT4
  • Check out my Pow Pow
« Reply #687 on: March 30, 2018, 02:15:49 pm »
Yeah the PSP dock looks great, looks like its possibly sanded and painted. If not then hot Dayumm. I also put Dampners on my CR10, need to get the metal extruder set though.
What design software are you using?
Besides all the badge holders I have been making, I made a Bi-Pod adapter for my Ruger 10/22 rifle.
Keep up the good work man
Titchgamer
« Reply #688 on: March 30, 2018, 02:47:39 pm »
Cheers guys,
Yeah the PSP dock I made in sketchup, Its not an amazing designer if ime honest but its easy for someone like me to work with.
The finish was just sanded, Primed and painted with spray paint, But it needed it as it was printed at .2 where I normally print at .12
Howard, The extruder drive I replaced is this one:
https://www.amazon.co.uk/HICTOP-Upgraded-Replacement-Aluminum-Extruder/dp/B076LQ9TPZ/ref=sr_1_3?ie=UTF8&qid=1522435506&sr=8-3&keywords=hictop+extruder
  • Last login:July 23, 2025, 07:04:20 pm
« Reply #689 on: March 30, 2018, 08:17:29 pm »
Drill guide for joysticks...  Happ standard and Sanwa JLF
Leaf switch holders:
« Reply #690 on: March 30, 2018, 09:44:31 pm »
Nice idea!  You actually beat me to it on the joystick guide.  One suggestion..... the peg in the center... you might want to put a hole just big enough for a pencil/pen to fit.  That way if you are also drilling the hole for the joystick you'll have a mark for the pilot bit on your hole saw.
« Reply #691 on: March 30, 2018, 09:51:24 pm »
Those are cool.   :applaud:
« Reply #692 on: March 31, 2018, 12:05:30 am »
WTF do you need a drill guide for? Mr. CNCman...?
%Bartop
« Reply #693 on: March 31, 2018, 01:37:17 am »
???  To drill the hole for the joystick when making a panel from scratch.  I thought that was pretty obvious.
Titchgamer
« Reply #694 on: March 31, 2018, 06:05:50 am »
Cool idea
Titchgamer
« Reply #695 on: March 31, 2018, 06:35:01 am »
Just remembered btw Howard,
I noticed my filament breaks if I have not used the printer for a week or 2, usually just infront of the extruder gear.
I guess the gear puts pressure on it over time and it breaks.
What I do to fix it is pull the Bowden tube out of the coupling that comes out of the extruder, pull the remnants of the fillament through them heat up the hot end to 200 and give it a sharp tug back down the bowden tube.
Then just feed new back in as normal.
« Reply #696 on: March 31, 2018, 09:34:57 am »
Not a bad idea.  :cheers:
« Reply #697 on: March 31, 2018, 09:49:01 am »
CNC... duh.
%Bartop
« Reply #698 on: March 31, 2018, 10:16:18 am »
CNC... duh.
I don't CNC everything all the time...
Titchgamer
« Reply #699 on: March 31, 2018, 11:46:19 am »
CNC... duh.
I would if I had access to a CNC
« Reply #700 on: March 31, 2018, 12:37:19 pm »
CNC... duh.
He doesn’t have direct access, which is good, since he doesn’t want MDF dust in his sandwiches.
Titchgamer
« Reply #701 on: March 31, 2018, 12:39:30 pm »
Ide totally be CNCing shapes in sarnies if I had the chance :p
  • Last login:Today at 02:08:10 pm
« Reply #702 on: March 31, 2018, 03:29:44 pm »
If/when you update this drill guide with a center hole as suggested above, you may also want to add a triangular notch on the center of each side.
Align the notches to horizontal and vertical lines drawn on the panel and your sticks are both perfectly positioned and squarely aligned.   :cheers:
« Reply #703 on: March 31, 2018, 07:06:52 pm »
Yeah there's gotta be an easier way though.  I've already added some g-code in my shutdown routine to push the bed out to present the finished part.... maybe if I add some code to back the filament up a bit it'll relieve some of the strain.
Titchgamer
« Reply #704 on: April 07, 2018, 05:02:09 pm »
Got my extra fan last night and run my first print since the upgrade.
OMG what a difference those dampeners make! The X/Y motors are now almost silent!
And the print came out perfect
« Last Edit: April 07, 2018, 05:05:14 pm by Titchgamer »
« Reply #705 on: April 07, 2018, 07:21:07 pm »
Yeah I need to invest in better bearings.  I've been looking into tool changes actually.... there have been a few a8 mods that allow for plotting, vinyl cutting and small scale cnc.  (Think pcb mill.)  I've just yet to see a carriage that looked sturdy enough for precision printing.  I think it is doable though.... I actually made a simple plotter attachment and it worked fine.
Titchgamer
« Reply #706 on: April 08, 2018, 03:12:43 am »
Yeah ive seen a few options for my printer, Laser cutters/etching and CNC stuff.
Not something ime ever likely to consider seriously though tbh.
Anything that small ide get the guys at work to do for me on a night shift lol
But yeah totally do the fan/dampener mods to your printer if you can.
It really is a game changer!!
  • Last login:Today at 06:15:33 am
« Reply #707 on: April 08, 2018, 02:25:17 pm »
Alien Poker almost back to life.
Old and busted on the right, new hotness left.
« Reply #708 on: April 08, 2018, 02:58:19 pm »
Nice.  I look forward to seeing that pin back in action.
So I found something useful:
https://www.thingiverse.com/thing:2070636
Ignore the part, that may or may not apply to you, but check out the program in the description.  That's what I've been looking for, an automated app to alter the gcode for x-axis plotting.  This would be useful for plotters, vinyl cutters and possibly even pcb milling.  See you need the code altered to basically keep the tool from dragging while moving about... it needs to retract for non 3d printing applications.
Titchgamer
« Reply #709 on: April 08, 2018, 06:30:17 pm »
Good stuff PBJ!
Ive just finished printing a prototype winder and speed loader for my TMC mags.
Its a bit rough but functional so ime going to do some further testing then smoothe it out a bit :)
« Reply #710 on: April 13, 2018, 04:24:47 pm »
So has anyone converted the anet a8 to use a Bowden style extruder?  I've been thinking about it since, in theory getting the weight off the carriage would eliminate wobble and increase the overall speed.  The only thing holding me back is the fact that I would have to print a new carriage.  I dunno, a pla carriage just doesn't seem like it would be sturdy.
But I mean the conversion itself is stupidly cheap.... you can get a j-head hotend complete with Bowden conversion parts for around 10 bucks on amazon.  I just wonder if I'm wasting my time.
Slippyblade
« Reply #711 on: April 13, 2018, 04:34:50 pm »
I'm sticking with direct drive since I plan on using flexible filaments soon.  Those don't work with a bowden setup.  If you are gonna stay with PLA, ABS, PetG, etc... I've heard bowden is great.
« Reply #712 on: April 13, 2018, 04:45:59 pm »
No interest. I’m fine with what mine does.
« Reply #713 on: April 13, 2018, 09:12:41 pm »
I would like the option to do ninjaflex and stuff but honestly I can't think of a use for it.  I'm trying to design a changeable head system as I'd really like to do a drag knife for vinyl and a laser for engraving and this just seemed like it would make the whole thing easier, but if my prints are going to suffer for it no dice.  I'm open to suggestions.
« Reply #714 on: April 13, 2018, 11:51:16 pm »
So this is pretty cool:
https://hackaday.com/2018/04/13/resuming-failed-3d-prints-automatically/
If the cost isn't terribly high this would be really nice for those 15 hour prints.
Titchgamer
« Reply #715 on: April 14, 2018, 01:52:34 am »
Sounds interesting that!
I wonder how it knows if you got spaghetti going on though??
« Reply #716 on: April 14, 2018, 07:50:43 pm »
PBJ just confirmed that several prints of v0.03 of the Williams Drop Target Guide (P/N 03-7479 or 3B-7479) are installed and working in his Alien Poker.
- v 0.03 - Narrowed columns, adjusted ramp, adjusted position of wall near ramp, enlarged bottom screw hole 10 Apr 18
- v 0.02 - Changed default screw hole sizes 27 Mar 2018
- v 0.01 - First draft 27 Mar 2018
This SCAD file recreates and remixes the model posted here on Thingiverse by Haruman's friend.
 - Corrections to that part are based on measurements of original parts
 - PCB columns changed to ovals for greater strength
 - Inspected by PBJ for accuracy and suitability
This part is used in Williams System 3-6 tables.
Planetary Pinball has online copies of Bally and Williams parts catalogs here.
The Williams 1980 catalog here contains related parts diagrams.
Drop target assemblies are on pages 113-118 -- they all use the 03-7479 guide.
The D-8362 assembly diagram on page 116 shows PCB screws that are the same P/N as the horseshoe screws. (4104-1001-06)
Drop target assemblies that use the 03-7479 guide:
     D-7931-#s  -  # = number of targets (between 1 and 5)
     D-8362     -  5 targets
     D-8442     -  3 targets
     D-9355     -  3 targets
Screw sizes:
 - #6-32 x 3/4" machine screw
 - #4 sheet metal screw
The attached .ZIP file contains the .SCAD file (you can modify the part using OpenSCAD) and .STL file.
Print with supports and your choice of filament -- the ones I sent to PBJ are Hatchbox PLA.
« Last Edit: April 14, 2018, 08:11:40 pm by PL1 »
« Reply #717 on: April 14, 2018, 10:40:14 pm »
« Reply #718 on: April 14, 2018, 11:06:11 pm »
So did you screw right into the holes or did you have to tap them first?  I'm only asking because I've had mixed success in regards to screwing into pla without it splitting.... seems to depend upon the model greatly.
« Reply #719 on: April 15, 2018, 12:15:02 am »
Screwed right in.
This part is unobtainium, other collectors I know are happy to see this come to fruition.  Found out one of my mosfets is blown on my $300 repro MPU.  But that’s another thread.
