Author Topic: White casing around LED Screen? Covering with black sprayed plexi bezel?  (Read 1426 times)
80sarcadegames
  • Last login:March 06, 2024, 09:03:51 pm
There is a 27" LED 1080p monitor available local to me for sale on Craigslist, but the casing is WHITE.
My problem is that my entire arcade cabinet is black, but I planned on doing the "spray paint the inside of the plexiglass with black spray paint" and then covering the the LED TV with the spray painted plexiglass bezel.
Do you think I will be forced to do the "de casing" routine because the white surrounding case around the TV will be visible, even
with the black spray painted plexiglass bezel covering the entire area of the TV casing?
80sarcadegames
Re: White casing around LED Screen? Covering with black sprayed plexi bezel?
« Reply #1 on: October 25, 2016, 10:03:30 am »
Edit: I just thought of a solution in addition to this.
I could remove the casing then spray paint the casing black if need be then put the casing back on.
But if I remove the remove the casing to do this, then why would I bother putting the casing back on?
Who the hell takes a casing off only to put it back on?  Lol.  :D :laugh2:
JDFan
« Reply #2 on: October 25, 2016, 10:37:37 am »
Could always tape off the monitor screen and spray the casing - no need to remove the casing  :dunno - or buy a small bottle of model paint and a small brush and paint the casing that way rather than spray.  :cheers:
MydknyteStyrm
  • Last login:March 20, 2024, 12:19:41 pm
  • Makeup FX Gamer
« Reply #3 on: October 26, 2016, 04:53:38 pm »
Use black electrical or duct tape. With the black painted bezel included you'll never see it.
thomas_surles
« Reply #4 on: October 26, 2016, 05:02:32 pm »
Cut some black poster board.
  • Last login:August 25, 2025, 01:22:15 am
« Reply #5 on: October 26, 2016, 09:58:35 pm »
You're using an LCD. Does it really matter about the bezel?
UEDan
  • Last login:November 10, 2019, 05:54:08 am
« Reply #6 on: October 27, 2016, 07:43:55 am »
I de-bezeled my screen. Taped it off and spray painted the metal cast black.
Mount monitor. Marked off plexi and sprayed the back plexi black as well.
You can never have spray enough black!
