Author Topic: GroovyMame 0.171 asio with LCD (again)  (Read 6733 times)
ApB1
  • Last login:July 23, 2017, 07:49:27 am
« on: October 18, 2016, 05:14:35 pm »
Hi
I know that GroovyMame is optimized for CRT and i use it in my Cab without any problems,
but i would like to use it on my Desktop-PC instead MameUI64/MameUIFX64.
PC is
Windows 10/64bit
i7
Nvidia GTX970
Benq Monitor 2560x1440, 30-222khz, 23-144hz
I created Refreshrates with the Nvidia Tool (all for 2560x1440): 23, 24, 25, 30, 33, 35, 40, 48-62, 66, 70, 72, 75, 80, 90, 96, 99, 100, 110, 120, 140, 144 - all testet and worked ok
With MameUI64/MameUIFX64 i used 'resoluton' 2560x1440 and 'refresh' auto
If i start, for example, R-Type MameUI64/FX64 switch to 56hz and the game runs at 102% (ok 55hz was nearer to original R-Type but Mame rounds up to 56hz and its OK for me)
If i start any game with GroovyMame it cant change the Refresrate. My Desktop-Refreshrate is 144hz and GroovyMame starts every game at 144hz
I tried many different settings in the mame.ini but the Refreshrate is always at 144hz
this shows the command window:
Video chipset is not compatible.
SwitchRes: [magmax] (1) horizontal (256x224@60.000000)->(2560x1440@60.000000)
Average speed: 240.01% (3 seconds)
it looks that GroovyMame change the refreshrate to 60hz but but my monitorinfo shows 144hz and the game runs at 240%
i know that Nvidia is not compatible with GroovyMame but the right refreshrates are present in my Windows (created with the Nvidia tool and also at the right place in the Registry/EDID)
Thanks...
My last mame.ini
Code: [Select]
# CORE CONFIGURATION OPTIONS
readconfig                1
writeconfig               0
# CORE SEARCH PATH OPTIONS
rompath                   roms
hashpath                  hash
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   .;ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
pluginspath               plugins
languagepath              language
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
input_directory           inp
state_directory           sta
snapshot_directory        snap
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  0
playback
record
record_timecode           0
exit_after_playback       0
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
snapbilinear              1
statename                 %g
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
syncrefresh               0
sleep                     1
speed                     1.0
refreshspeed              0
# CORE ROTATION OPTIONS
rotate                    1
ror                       0
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              1
use_backdrops             0
use_overlays              0
use_bezels                0
use_cpanels               0
use_marquees              0
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
effect                    none
# CORE VECTOR OPTIONS
antialias                 1
beam_width_min            1.0
beam_width_max            1.0
beam_intensity_weight     0
flicker                   0
# CORE SOUND OPTIONS
samplerate                48000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              1
ctrlr
mouse                     0
joystick                  1
lightgun                  0
multikeyboard             0
multimouse                0
steadykey                 0
ui_active                 0
offscreen_reload          0
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
joystick_contradictory    0
coin_impulse              0
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          keyboard
lightgun_device           keyboard
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
verbose                   0
log                       0
oslog                     0
debug                     0
update_in_pause           0
debugscript
# CORE COMM OPTIONS
comm_localhost            0.0.0.0
comm_localport            15112
comm_remotehost           127.0.0.1
comm_remoteport           15112
# CORE MISC OPTIONS
drc                       1
drc_use_c                 0
drc_log_uml               0
drc_log_native            0
bios
cheat                     0
skip_gameinfo             0
uifont                    default
ui                        cabinet
ramsize
confirm_quit              0
ui_mouse                  1
autoboot_command
autoboot_delay            2
autoboot_script
console                   0
language                  English
# CORE MKChamp OPTIONS
disable_hiscore_patch     0
disable_nagscreen_patch   1
disable_loading_patch     1
# CORE SWITCHRES OPTIONS
modeline_generation       1
monitor                   lcd
orientation               horizontal
connector                 auto
interlace                 0
doublescan                1
cleanstretch              1
changeres                 1
powerstrip                0
lock_system_modes         0
lock_unsupported_modes    0
refresh_dont_care         1
dotclock_min              0
sync_refresh_tolerance    2.0
frame_delay               0
vsync_offset              0
black_frame_insertion     0
modeline                  auto
ps_timing                 auto
lcd_range                 49-144
crt_range0                auto
crt_range1                auto
crt_range2                auto
crt_range3                auto
crt_range4                auto
crt_range5                auto
crt_range6                auto
crt_range7                auto
crt_range8                auto
crt_range9                auto
# OSD KEYBOARD MAPPING OPTIONS
uimodekey                 SCRLOCK
# OSD FONT OPTIONS
uifontprovider            auto
# OSD DEBUGGING OPTIONS
debugger                  auto
debugger_font             auto
debugger_font_size        0
watchdog                  0
# OSD PERFORMANCE OPTIONS
multithreading            1
numprocessors             auto
bench                     0
# OSD VIDEO OPTIONS
video                     d3d9ex
numscreens                1
window                    0
maximize                  1
keepaspect                0
unevenstretch             0
waitvsync                 0
# OSD PER-WINDOW VIDEO OPTIONS
screen                    auto
aspect                    auto
resolution                auto
view                      auto
screen0                   \\.\DISPLAY1
aspect0                   auto
resolution0               2560x1440@0
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# OSD FULL SCREEN OPTIONS
switchres                 1
# OSD ACCELERATED VIDEO OPTIONS
filter                    1
prescale                  1
# OpenGL-SPECIFIC OPTIONS
gl_forcepow2texture       0
gl_notexturerect          0
gl_vbo                    1
gl_pbo                    1
gl_glsl                   0
gl_glsl_filter            1
glsl_shader_mame0         none
glsl_shader_mame1         none
glsl_shader_mame2         none
glsl_shader_mame3         none
glsl_shader_mame4         none
glsl_shader_mame5         none
glsl_shader_mame6         none
glsl_shader_mame7         none
glsl_shader_mame8         none
glsl_shader_mame9         none
glsl_shader_screen0       none
glsl_shader_screen1       none
glsl_shader_screen2       none
glsl_shader_screen3       none
glsl_shader_screen4       none
glsl_shader_screen5       none
glsl_shader_screen6       none
glsl_shader_screen7       none
glsl_shader_screen8       none
glsl_shader_screen9       none
# OSD SOUND OPTIONS
sound                     dsound
audio_latency             0.1
# ASIO OPTIONS
asio_device               0
asio_log                  0
# WINDOWS PERFORMANCE OPTIONS
priority                  0
profile                   0
# WINDOWS VIDEO OPTIONS
menu                      0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D POST-PROCESSING OPTIONS
hlsl_enable               0
hlslpath                  hlsl
hlsl_prescale_x           0
hlsl_prescale_y           0
hlsl_write
hlsl_snap_width           2048
hlsl_snap_height          1536
shadow_mask_tile_mode     0
shadow_mask_alpha         0.0
shadow_mask_x_count       6
shadow_mask_y_count       4
shadow_mask_usize         0.1875
shadow_mask_vsize         0.25
shadow_mask_uoffset       0.0
shadow_mask_voffset       0.0
curvature                 0.0
round_corner              0.0
smooth_border             0.0
reflection                0.0
vignetting                0.0
scanline_alpha            0.0
scanline_size             1.0
scanline_height           1.0
scanline_bright_scale     1.0
scanline_bright_offset    0.0
scanline_jitter           0.0
hum_bar_alpha             0.0
defocus                   1.0,0.0
converge_x                0.25,0.00,-0.25
converge_y                0.0,0.25,-0.25
radial_converge_x         0.0,0.0,0.0
radial_converge_y         0.0,0.0,0.0
red_ratio                 1.0,0.0,0.0
grn_ratio                 0.0,1.0,0.0
blu_ratio                 0.0,0.0,1.0
saturation                1.4
offset                    0.0,0.0,0.0
scale                     0.95,0.95,0.95
power                     0.8,0.8,0.8
floor                     0.05,0.05,0.05
phosphor_life             0.4,0.4,0.4
# NTSC POST-PROCESSING OPTIONS
yiq_enable                0
yiq_jitter                0.0
yiq_cc                    3.57954545
yiq_a                     0.5
yiq_b                     0.5
yiq_o                     0.0
yiq_p                     1.0
yiq_n                     1.0
yiq_y                     6.0
yiq_i                     1.2
yiq_q                     0.6
yiq_scan_time             52.6
yiq_phase_count           2
# VECTOR POST-PROCESSING OPTIONS
vector_length_scale       0.5
vector_length_ratio       500.0
# BLOOM POST-PROCESSING OPTIONS
bloom_blend_mode          0
bloom_scale               0.25
bloom_overdrive           1.0,1.0,1.0
bloom_lvl0_weight         1.0
bloom_lvl1_weight         0.64
bloom_lvl2_weight         0.32
bloom_lvl3_weight         0.16
bloom_lvl4_weight         0.08
bloom_lvl5_weight         0.04
bloom_lvl6_weight         0.04
bloom_lvl7_weight         0.02
bloom_lvl8_weight         0.02
bloom_lvl9_weight         0.01
bloom_lvl10_weight        0.01
# FULL SCREEN OPTIONS
triplebuffer              0
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# INPUT DEVICE OPTIONS
global_inputs             0
dual_lightgun             0
« Last Edit: October 21, 2016, 04:37:40 am by Calamity »
machyavel
  • Last login:December 25, 2016, 10:23:52 am
Re: GroovyMame 0.171 asio with LCD (again)
« Reply #1 on: October 19, 2016, 04:23:00 pm »
Try to change your desktop resolution to anything but 2560x1440 before using groovymame.
ApB1
« Reply #2 on: October 19, 2016, 05:27:19 pm »
i changed my Desktopresolution to 1920x1080  50hz and started a game:
D:\Emulation\MAME\__MAME32\_GroovyMame>GroovyMame64_0171asio magmax
SwitchRes: [magmax] (1) horizontal (256x224@60.000000)->(1920x1080@60.000000)
GroovyMame dont try to change the Resolution to 2560x1440  as defined in the mame.ini
and it dont changed the refreshrate to 60 hz (1920x1080) as shown above, my Monitor Info shows 50hz
Of course, if i change to the right refresh rate before i start a game that it runs at the right refresh rate.
But i would run GroovyMame with an Frontend like MaLa and i wish that GroovyMame changes to the right refreshrate automatically...
« Last Edit: October 19, 2016, 05:39:17 pm by ApB1 »
machyavel
« Reply #3 on: October 19, 2016, 07:23:15 pm »
Ok sorry, had this kind of issue on my CRT+LCD setup (i.e. GM cannot change a res that desktop is set to).
Unfortunately I have no experience in running GM on multisync LCD.
Anyway you should post a log so one can have a look at what's going on.
lettuce
  • Make It So!
« Reply #4 on: October 20, 2016, 06:03:52 am »
I think what you need to do what your asking is either a Freesync or Gsync monitor.
As with my Gsync Asus monitor all i have to do is change....
waitvsync 0
monitor   lcd
lcd_range 50-144
triplebuffer 0
in mame.ini set the
Then test with Mortal Kombat on the title screen where the character avatars are scrolling down either side of the screen, they should be scrolling completely smoothly
ApB1
« Reply #5 on: October 20, 2016, 07:20:02 am »
Ok, the FreeSync and GSync solutions are another solution approaches (my Benq Monitor has FreeSync but my GraphicCard is a Nvidia GTX970 ;-(  )
But i don't understand why GroovyMame can't change the Refreshrates which are disposal by Windows/EDID/Nvidia driver.
in my make.ini i have set
lock_system_modes         0
so why can't GroovyMame grab the right Refreshrate which provides the OS ?
and why can't GroovyMame not switch the Resolution?
for a Test i changed the desktop resolution to 1920x1080@50hz,
in the mame.ini is the resolution set to:
aspect0                   auto
but the game started with the test resolution 1920x1080@50hz
Calamity
  • Moderator
  • Last login:Today at 05:16:07 am
  • Quote me with care
« Reply #6 on: October 21, 2016, 04:43:35 am »
Because you're using the "lcd" monitor preset, which is supposed to keep the desktop resolution whatever it is.
If you want automatic mode switching, you need to create a monitor preset of the "crt_range" type. Post a log of a random game with your current config (not mame.ini, a log).
Steps to create a log:
ApB1
« Reply #7 on: October 21, 2016, 03:57:03 pm »
ok i would try with a crt range type
but what for is the option
lcd_range                 49-144 ?
oomek
  • Last login:October 24, 2025, 01:13:40 pm
  • Mame forever.
    • https://github.com/oomek
« Reply #8 on: November 02, 2016, 07:07:34 am »
I have the same problem. Did you get this working on your LCD?
ApB1
« Reply #9 on: November 04, 2016, 06:05:10 pm »
until now - no
i dont know how i can create a right CRT preset with my specifications (25-222khz 23-144hz)
but i dont understand the option 'lcd_range' is what for.
It seems it must do the same but it doesnt.
Calamity
  • Moderator
ApB1
« Reply #11 on: November 06, 2016, 06:39:20 pm »
hi,
here the LOG.
in the LOG it seems the game startet with 60hz but it starts with 144hz.
« Last Edit: November 06, 2016, 06:42:40 pm by ApB1 »
ApB1
« Reply #12 on: November 07, 2016, 05:04:02 am »
Ok, after reading the other liked thread and some testing i got one step forwarth.
but now, the 'cleanstretch' option and the 'filter' option does not work
« Last Edit: November 07, 2016, 05:06:47 am by ApB1 »
oomek
  • Mame forever.
« Reply #13 on: November 07, 2016, 05:18:59 am »
It was also explained in the thread I started. 0.171 is forcing prescaler to 3
ApB1
« Reply #14 on: November 07, 2016, 02:03:34 pm »
Ok, one more -
R-Type starts correctly in 55 hz, the 'prescale 1' option (in command line not in mame.ini) works
'Magmax' and, for example 'Elevator Arction', both 60hz games, choose 48hz and 'prescale 1' is not working, and the aspect of the games are not correct.
Both games are stretched 16:9 Fullscreen
oomek
  • Mame forever.
« Reply #15 on: November 07, 2016, 03:18:10 pm »
You need also to add -filter in the commandline
ApB1
« Reply #16 on: November 07, 2016, 03:47:07 pm »
ok, the filter option works by magmax and elevator action but in R-Type 'prescale 1' works fine without the 'filter' option.
the problems with 48hz instead 60hz and 16:9 Fullscreenstretch in magmax and elevator action is still present.
Calamity
  • Moderator
« Reply #17 on: November 07, 2016, 04:28:16 pm »
Remind to add the option -aspect 16:9 in mame.ini, this is required in order to calculate the correct aspect.
Version 171 still had the old scaling options. Since then, integer scaling has been implemented natively in MAME, in combination with -unevenstretchx etc, which now do a much better job.
I'd rather you used updated versions so I didn't need to troubleshoot older ones which worked in a different way. The specific issue with the wrong refresh being selected, is the one I'm interested in, I'd like to see how v0.179 behaves on that.
I know you're sticking to 171 for D3D9ex and ASIO but unfortunately you'll need to live without those until we find a way to replace/reimplement both.
ApB1
« Reply #18 on: November 07, 2016, 05:22:08 pm »
i tried groovymame64 0.179
Magmax run at 60hz but infoscreen shows 48hz
R-Type run at 60hz but infoscreen shows 55hz
oomek
  • Mame forever.
« Reply #19 on: November 07, 2016, 08:37:10 pm »
I have exactly the same problem with 0.179, all games are running at 60Hz even though the log says otherwise. That's the main reason (apart from the obvious d3d9ex benefits) i'm sticking with 0.171
Update: it's worth to mention that it's a bgfx problem, not the 0.179. It happens also in 0.171. But I have no other option since d3d9ex is missing.
It would be awesome if the dev has decided to implement back the d3d9ex renderer.
« Last Edit: November 07, 2016, 08:40:45 pm by oomek »
ApB1
« Reply #20 on: November 08, 2016, 06:29:37 am »
my Situation is:
in GroovyMame 0.171
Magmax, Elevator Action etc. (all original 60hz) runs with 48hz, Log shows 48hz
R-Type (original 55hz) runs with 55hz, Log shows 55hz
GroovyMae 0.179
Magmax, Elevator Action etc. (all original 60hz) runs with 60hz, Log shows 48hz
R-Type (original 55hz) runs with 60hz, Log shows 55hz
besides the other Refresh Problems (between groovy 0.171 and groovy 0.179)
why does GroovyMame set the 60hz games to 48hz? (48hz is my lowest for GroovyMame released refresh rate)
ApB1
« Reply #21 on: November 08, 2016, 06:30:39 am »
my Situation is:
in GroovyMame 0.171
GroovyMame 0.179
why does GroovyMame try to set or set the 60hz games to 48hz? (48hz is my lowest for GroovyMame released refresh rate)
« Last Edit: November 08, 2016, 06:35:25 am by ApB1 »
Calamity
  • Moderator
« Reply #22 on: November 08, 2016, 07:08:13 am »
1.- The issue with rtype is due to bgfx (same as oomek reported). Use -video d3d and it will be ok.
2.- The issue with magmax is different, is due to the pick-best-mode algorithm not working properly with the automatic crt_range we're introducing and the lcd case. It could probably be fixed by tweaking the crt_range, I'll check when I have some time.
« Last Edit: November 08, 2016, 08:15:00 am by Calamity »
Calamity
  • Moderator
« Reply #23 on: November 08, 2016, 08:22:23 am »
This should fix issue 2:
crt_range0 75120.00-98595.00,48.00-63.00,0.287,0.347,0.634,0.004,0.013,0.100,0,1,1344,1440,0,0
(lower back porch and some border tolerance (224 * 6 = 1344)
As an attempt to fix issue 1, check the google drive for this file: groovymame64_0179.016_alpha3_test.7z
It should fix the full screen refresh issue, not sure if iit has any undesired side effect.
oomek
  • Mame forever.
« Reply #24 on: November 08, 2016, 09:11:14 am »
Your test build works, no more 60hz. Unfortunately I'll have to emphasize it again. The latency with bgfx is not even neart that what can be achieved with d3d9ex. I'm begging you, please add it back.
Calamity
  • Moderator
« Reply #25 on: November 08, 2016, 11:53:35 am »
I'm really interested in knowing how much difference there is, you said you are measuring it with an arduino, do you have any figures to compare?
oomek
  • Mame forever.
« Reply #26 on: November 08, 2016, 12:44:34 pm »
I was going to do it right now, but my camera refused to work saying the battery reached the end of it's life and needs to be replaced. Murphy's law at it's best. Trying to recharge it now, be patient please.
oomek
  • Mame forever.
« Reply #27 on: November 08, 2016, 01:14:31 pm »
Damn thing still refuses to work. Bought a new battery on Amazon, will arrive tomorrow.
ApB1
« Reply #28 on: November 09, 2016, 04:59:51 pm »
this change have sovled the problem on both versions 0.171asio and 0179.016_alpha3_test
Magmax runs now with 60hz
but R-Type runs now with 54hz (55hz before the change in the crt_range)
« Last Edit: November 09, 2016, 05:04:51 pm by ApB1 »
oomek
  • Mame forever.
« Reply #29 on: November 09, 2016, 07:10:49 pm »
@Calamity OK, I've done a lot of measurements and the results will shock you. I hope you'll understand now my stubbornness.
XLS with a report:
https://onedrive.live.com/view.aspx?resid=1EF40962E42ABF0B!442&ithint=file%2cxlsx&app=Excel&authkey=!AHU5WnqbyUsYejo
Folder with high speed videos:
https://drive.google.com/open?id=0ByeL6qQUr-iUeDYtWnN5SXR3V3M
I measured the latency using the following method:
Orange led turning on as a start frame and as an end frame the dim one just before head of the ninja starts fading(my TV goes dim a little on every vblank, so it was easy to spot).
Can't wait for your decision.
p.s. The lag difference between frame_delay 2 and 10 is negligible as you can see. That's why I use 10. That gives me total control over a tear line (it's stable as a rock, always in one place)
p.s.2 Don't mind a huge latency of my TV. It has 60ms on average.  That's why every ms matters to me. I'm planning to upgrade soon to something faster.
« Last Edit: November 09, 2016, 08:20:34 pm by oomek »
