Author Topic: IPAC not being detected by WinIPAC?  (Read 3297 times)
hunterjwizzard
  • Last login:September 08, 2016, 09:29:08 pm
« on: September 05, 2016, 07:11:22 pm »
Hi folks, not sure this is the best place to post, but here is my problem: I have the Ipac board and am building controls around it, but I cannot get the WinIPAC V2 software to read the board. I know its hooked and working because when I hit buttons I am getting characters, but even hooked directly to the PC(no USB hub/extension cable/etc) the software still does not detect a board.
Any help will be appreciated, thanks.
brad808
  • Last login:May 22, 2023, 08:18:15 pm
Re: IPAC not being detected by WinIPAC?
« Reply #1 on: September 05, 2016, 07:12:43 pm »
Is it an older board? Should you be using the original winipac and not version 2?
hunterjwizzard
« Reply #2 on: September 05, 2016, 07:53:04 pm »
Yep, that did the trick. I had thought I had an Ipac2, thanks!
