Author Topic: Road Blaster yoke  (Read 1704 times)
wbassett
  • Last login:October 05, 2024, 02:18:42 am
Road Blaster yoke
« on: June 19, 2016, 02:26:37 pm »
Can a Road Blaster yoke be converted to work as a Star Wars yoke?
  • Bitches love Centipede
Re: Road Blaster yoke
« Reply #1 on: June 19, 2016, 02:53:58 pm »
Nope.
%Bartop
  • Last login:Today at 04:39:10 am
« Reply #2 on: June 19, 2016, 03:18:33 pm »
Road Blasters used an optical mechanical (mouse type) sensor, while Star Wars used POTs (analog joystick type), and mame emulates it like that (RB uses a DIAL, SW uses a AD_STICK)   Also, RB didn't use the Y axis, unless someone hacked it to take the place of the foot pedal.
While they look similar, the 1-axis optical steering wheel from Road Blasters will not easily convert to a 2-axis potentiometer yoke like Star Wars.
There are a number of yokes that you can use (or easily adapt) for Star Wars -- check out the list of (analog joystick) yoke games in the right column here.   :droid
(definitely avoid Paperboy and Two Tigers yokes)
« Reply #3 on: June 20, 2016, 01:49:15 pm »
The real problem is that generally the controllers that can be converted for Star Wars are actually more expensive than a Star Wars yoke.  Try finding a Paperboy controller now.  Yikes.
nitrogen_widget
  • Last login:November 19, 2025, 07:10:59 am
« Reply #4 on: June 24, 2016, 02:35:23 pm »
Somewhere (possibly on this site) I saw someone use a generic yoke as a starwars yoke by mounting the yoke to a control panel that hinged out to create a 2nd axis.
