Author Topic: sound card most inputs!  (Read 2556 times)
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
« on: January 16, 2004, 09:37:09 pm »
Just curious but what sound card can handle the most drives? The sound blaster I use now only allowes for two inputs from my drives CD\DVD. I was really hoping for three or four. Is there a Y connection maybe? If so does anyone know were I might locate one. Thanks in advance.
Mameham
  • Last login:August 16, 2005, 01:29:36 pm
  • The Original Home Arcade Machine
    • Mameham
Re:sound card most inputs!
« Reply #1 on: January 19, 2004, 05:23:01 pm »
 I'd be damned surprised if you couldn't build your own y-cable... Just splice one together... I'm sure you can get a bunch of the cables from E-bay cheap and they play around with it...
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #2 on: February 03, 2004, 08:41:48 am »
it was a while ago but i picked up a cable at radioshack for pretty cheap that splits to 2
"Owens is the ringleader in the ass hat circus"  D K
papaschtroumpf
  • Last login:July 23, 2013, 11:41:10 pm
  • Have a Cow!
« Reply #3 on: February 03, 2004, 05:40:42 pm »
I'mm curious, why so many?
Also nowadays you can set a lot of drive for playback directly through the PCI bus, without using a cable between the CD-ROM and the sound card.
