Author Topic: Makvision M2929 and ActLab vga lightgun  (Read 2917 times)
TapeWormInYourGut
  • Last login:August 17, 2025, 06:31:27 pm
« on: May 17, 2016, 07:43:45 pm »
Hello everyone, I searched a bit but didn't see anyone using the VGA ActLab gun on the SVGA MakVision monitor. I got a set of ActLab guns off of ebay and I now plan on modifying some arcade guns with the guts of the ActLab guns. I want to make a dedicated lightgun cab and am looking at the MakVision SVGA monitor. Does anyone have the same setup who can verify that those 2 work together, using a standard videocard and not the ArcadeVGA card? I don't want to spend such a large chunk of change on the M2929 only to find out that there are problems getting it to work.
I modified some recoil arcade guns with aimtraks, but I am a bit unhappy with the calibration requirements. The aimtraks are great when playing alone, but require calibration every time you hand the gun off. Or even moving over a foot would throw off the calibration. Re-calibration requires you to exit to the desktop, run the routine, and then restart the game. It is a bit annoying when playing in a party, where you switch off frequently with other people.
Argonlefou made a "DemulShooter" utility which looks like it could allow 2-player using the ActLab guns. Previously, dual "real" lightguns were a pain outside of mame. A dedicated cab was out of the question before, but now I am thinking that it is worth it.
http://forum.arcadecontrols.com/index.php/topic,149714.msg1563085.html#msg1563085
