Author Topic: Fluorescent Light Wiring Question  (Read 1514 times)
« on: April 11, 2016, 06:50:47 pm »
One of the cabinets I'm working on has a fluorescent fixture that I'd like to re-use.  The manual says that it is a 115 VAC fixture.  Can I plug this into a 110 socket or do I need to get a new ballast?  I assume it will work but will be slightly dimmer.
Slippyblade
Re: Fluorescent Light Wiring Question
« Reply #1 on: April 11, 2016, 07:01:56 pm »
115, 110, 120...
All the same.  It's AC, so the number you are using depends on exactly which formula is being used.
« Reply #2 on: April 11, 2016, 08:05:18 pm »
Thanks!   :cheers:
Slippyblade
« Reply #3 on: April 11, 2016, 08:24:55 pm »
The only time it really comes up is if you move countries.  The US and I think Canada both use 110 so anything listed near that works.  Europe uses 220.  So country really becomes the deciding factor when dealing with AC.  Well, unless you are talking high voltage AC in the states - that's 220.  :)
dmckean
« Reply #4 on: April 11, 2016, 08:32:58 pm »
Japan is confusing too. 100V and half the country is on 50hz and the half is on 60hz.
Slippyblade
« Reply #5 on: April 11, 2016, 09:01:20 pm »
Holy crap.  That's gotta play havoc on timing circuits.
« Reply #6 on: April 11, 2016, 09:50:57 pm »
That's exactly why I asked my dumb question.  I wondered if I had a Nintendo situation going on.
