Author Topic: force radion  (Read 5940 times)
joe4
  • Last login:March 29, 2016, 02:06:32 pm
force radion
« on: March 18, 2016, 12:24:48 pm »
so I have a megatouch force radion 2005.5. When I start the machine up I can here the tube power up but no fans start up. I replaced the power supply today and nothing changed. the screen is black like its not working. the mother board has a red light on when power is on. please help
lilshawn
  • Moderator
  • Last login:October 16, 2025, 06:18:08 pm
Re: force radion
« Reply #1 on: March 18, 2016, 01:43:42 pm »
best to post in the merit/JVL touchscreen sub for maximum exposure...
http://forum.arcadecontrols.com/index.php/board,54.0.html
the battery on the board has likely died. the motherboard BIOS is normally set to come on after the power is lost, but by default it stays off. pull the board and change the button cell battery on the actual motherboard (CR2032)
connect a keyboard and then you can then jumpstart the board by jumping the 2 power switch connectors on the board. On the force boards the header is located in the very corner of the board. if you where to hold the board with the board components facing you and the monitor/keyboard/usb connectors to the top it would be on the bottom left side. it will have a black connector overtop of all the pins with 1 or 2/3 black/white wires (depends on version) on it. just pull the block connector off and jump the power switch pins. I don't recall exactly which 2 pins...it's at the end of the block of pins.
once you have the board going press delete to enter the bios and change the "On AC power loss" to "on"
if the board refuses to power up,  may have a bigger issue.
« Last Edit: March 18, 2016, 01:45:58 pm by lilshawn »
joe4
Re: force radion
« Reply #2 on: March 18, 2016, 04:28:42 pm »
Thanks lilshawn everything is working again. I Just did what you said. :applaud:
lilshawn
  • Moderator
Re: force radion
« Reply #3 on: March 18, 2016, 04:54:25 pm »
no problem. it's a common issue.    :cheers:
I also recommend taking the heatsink off the CPU and cleaning off the thermal interface material they used on there. it's 100% crap. I do every force board that comes across my desk.
You are going to need to use something pretty strong to get it off. (lacquer thinner, contact cleaner, or acetone.) clean it off squeaky clean and put some good quality heatsink grease under there. these processors tend to overheat easily. changing the heatsink grease will keep things lots cooler and last much longer.
otsep
  • Last login:September 28, 2025, 02:53:45 pm
  • I'm your huckleberry...
Re: force radion
« Reply #4 on: June 08, 2016, 10:03:09 pm »
What thermal compound do you recommend?
Vids: Namco Rockin' Bowl-O-Rama
Pins: Aerosmith Pro, ST Premium Vault, Beatles Gold
Remember Wheaton's Law
lilshawn
  • Moderator
Re: force radion
« Reply #5 on: June 09, 2016, 04:34:15 pm »
anything really... I use whatever i happen to have.
I tend to gravitate towards the silicone based compounds, they are not conductive and tend to resist drying out.
I'm currently using this:
http://www.rpelectronics.com/860-150g-silicone-heat-sink-compound-mg-chemicals.html
mainly because over the course of a year i'll do thermal compound on literally 100's of FETs, regulators, CPU's, GPU's, etc. so i buy in bulk.
from cheapest to best most expensive compound out there performce is really nil.  so really, whatever you got...use.
otsep
Re: force radion
« Reply #6 on: June 09, 2016, 04:37:25 pm »
I haven't bought any yet, so thanks for the pointer.  I need to find a damn IDE DVD drive to reinstall software.  Good times.
ed12
Re: force radion
« Reply #7 on: June 09, 2016, 08:56:06 pm »
klov has an exelent d/l page for  merit
ed
