Author Topic: Question about Control Panel...  (Read 1424 times)
JamesS
  • Last login:May 09, 2014, 03:26:43 pm
  • Just getting Started, Bare with me...
« on: January 14, 2004, 01:05:28 pm »
Ok, I notice it looks like everone bolts their joystick from the bottom.  What size hole do you use for where the Joystick sticks up?
I thought originally you just cut a square hole, set the Part of the Joystick with switches into it and then bolt it to the top.
But I got to thinking that did not seem right.  So what do people use as normally?
Sorry if this is another stupid question.
Tiger-Heli
    • Tiger-Heli
Re:Question about Control Panel...
« Reply #1 on: January 14, 2004, 01:19:48 pm »
Generally 1-1/8, same as the buttons.  Could go wider if using really thick wood.  You could cut a square recess into the bottom of the wood, but you probably don't want a hole (unless you are using a mounting plate).
JamesS
« Reply #2 on: January 14, 2004, 01:24:38 pm »
Thanks.  I am using 3/4 MDF, I will try the same size as the Button hole to start with, if not good enough.  Well, I will cross that bridge when I get to it.
Thanks.
Jakobud
  • Last login:December 23, 2025, 02:48:26 am
« Reply #3 on: January 14, 2004, 01:30:03 pm »
the only things you have to think about when drilling the hole are these:
1. bigger than the shaft of the joystick (obviously)
2. large enough that the shaft can move in all directions freely
3. small enough that the dust cover covers it up.
JamesS
« Reply #4 on: January 14, 2004, 01:54:05 pm »
Thanks Jako.
tep0583
  • Last login:October 26, 2009, 05:00:51 pm
« Reply #5 on: January 14, 2004, 02:27:04 pm »
I believe I went 1-1/4 and it seemed to work just fine. I did the same fo the buttons (couldn't find a decent 1-1/8 at the time) and the holes were too big for the buttons, but still useable. If you position the buttons carefully, it will cover all of a 1-1/4 hole, however....
