Author Topic: Rowe cd100d  (Read 1934 times)
bartonbrass
  • Last login:January 31, 2016, 09:57:01 pm
Rowe cd100d
« on: January 27, 2016, 04:08:25 pm »
We have a Rowe cd-100d, when I play a cd the cd spins up then stops, then it will spin backwards, do that a couple times then stop.  I looked at the diagnostic codes and service manual and can't figure out what I should check/do next.  We've had the JB for years and haven't had any issues.  I did unplug all the wires from the ccc and make sure they were seated properly.  Also we have no neon lights, any help would appreciated: )
Thanks!!
Jake
jdemarti
  • Last login:May 31, 2022, 10:57:25 am
Re: Rowe cd100d
« Reply #1 on: January 28, 2016, 09:42:31 pm »
Could be a bad optical pickup unit (laser) or the turntable motor. Worst case could be the circuit board in the player is bad.
bartonbrass
Re: Rowe cd100d
« Reply #2 on: January 31, 2016, 09:54:01 pm »
I'm supprised that it not saying out of order.   It looks like if it was the CCC the board error led would be lit.   Wonder how I would check to see if the optical pickup is bad?
ed12
Re: Rowe cd100d
« Reply #3 on: January 31, 2016, 10:17:11 pm »
please list the error code./'s
ed
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: Rowe cd100d
« Reply #4 on: February 01, 2016, 06:33:21 am »
Hi Jake,
We need more information regarding your jukebox.
CDM? what type of laser is fitted CDM3, CDM4, CDM12, CD-PRO.
I agree we also need the error codes that you saw on the jukebox.
Regards
Alan
Alan Hood
ami-man
UK
