Author Topic: Best Button Controls  (Read 10123 times)
skinzz
  • Last login:March 10, 2019, 12:12:16 am
« on: January 03, 2016, 11:47:42 am »
I had a bit of difficulty searching this forum, though I'm sure the answer is probably on here somewhere so I will apologize in advance if the question has been asked many times before.
I'd like to get the general opinion of the forum of who makes the best buttons for a custom built MAME arcade. I'm looking to build something with lit buttons (LED), but want to build a CP with good button response on the action buttons, so some click you can feel. I'm new to all this, but want an authentic experience so I can share a bit of my childhood with my son.
05SRT4
  • Check out my Pow Pow
Re: Best Button Controls
« Reply #1 on: January 03, 2016, 01:04:55 pm »
Hi Skinzz, Welcome to the forum.
Its hard to determine the Best Button out there because everyone has there own preference and feel. Keep in mind that you can swap out the micro-switch of each arcade button. So if you like the style of the button but the micro-switch just doesn't feel right you can always try another till your satisfied with the feedback.
A couple of questions though:
You mentioned you were looking into LED style buttons. Did you want the whole button to be lit up or just the outside (halo style)?
Did you want single LED colors or Multi RBG?
Have you looked at any retailers yet or have a specific button you might be interested in already.
Was there a specific arcade that you liked the feel on? We can always see what buttons and switches they used.
skinzz
« Reply #2 on: January 03, 2016, 01:48:03 pm »
Thanks 05SRT4!
I'd like the entire button to be illuminated, and one color would be fine. I like the concept of the RBG, but that might be more electronic components/configuration than I'm comfortable dealing with at this early stage.
It sounds like Happ is a popular option, though I've been browsing GroovyGameGear and like the look of the ChromaLite Illuminated Pushbuttons - not sure of the quality of those but did note the various micro-switch options.
I can't say there's a specific arcade I had a preference on button feel. Pacman/Galaga is probably my favorite game but it's not due to the buttons. I think I would prefer the top player select, coin, function, etc buttons to be more "clicky" than the action buttons if that makes sense, but I assume that can be done with the micro-switch.
Xiaou2
  • Last login:Yesterday at 06:42:48 pm
  • NOM NOM NOM
« Reply #3 on: January 03, 2016, 07:30:02 pm »
Galaga used a Leaf-Switch.   As such, for the Authentic experience,  you should try to find some used leafswitch buttons.
 Leafswitches are best for rapidfire games.... or games that you do a ton of constant shooting it... such as Galaga.
The reason for this.. is that once you get past the initial resistance depth... and the two leaf contacts connect.. you can pretty much vibrate your finger lightly, for hair trigger rapidfire responses... that take pretty much no effort at all.   Its often called  "Floating".
 Microswitches however, have a hard spring tension to overcome initially.   They Snap open and closed very abruptly...  so you will always have to re-press them fully again,  encountering that harsh resistance all over again.   In time, this causes a lot of fatigue to your fingers / hand.  Also, when you bottom out a microswitch,  its hits with a heavy impact.   This impact forces travels into the button.. and into your finger... causing further discomfort and fatigue.
 With a leaf button... you dont have to fully bottom it out to active them... and its easy to keep from bottoming them out.   As such, its smooth and silent..  like bouncing on a springboard or trampoline.   No more impact fatigue.
 With that said... if you want to play fighting games... you will want microswitch equipment, such as the happ buttons and competition joystick.  The extra resistance they provide, helps keep you from accidentally making a mistaken activation... and the tactile feedback lets you know as well.
 If you like Pacman games... then you really need a 4 way joystick as well.   The physical diamond shaped restriction, is unmatched in feel and response for 4 way game play.
 As for Microswitch button type... I prefer buttons with a concave top.  They cradle the fingers nicely and comfortably.. and keep them from sliding off.   More modern Japanese cabinets started making flat and convex buttons.. and it really baffles me as to why.
 I have a person distaste for the new hybrid technologies.. such as the mico-leafs.   They are too sensitive IMO.. and its easy to Accidentally fire, with almost no pressure put on them.  There is not as much button travel possible, and so even the best adjusting, will not allow them to feel, react, and perform...  the same way as a typical old classic leafswitch button.
 Lighting to me has always been 2ndary to feel, comfort, and control..   but really, almost anything can be lit with a little modding,  if needed.
  • Last login:December 18, 2025, 07:06:30 pm
« Reply #4 on: January 03, 2016, 07:39:34 pm »
IL/Happ Concave buttons are the best out there.
Let the opinions fly.
adder
« Reply #5 on: January 03, 2016, 08:25:20 pm »
Quote from: Xiaou2
i use a combination of very light springs and very light action microswitches (cherry light/soft click) to overcome this problem (along with buttons which have a short travel to the microswitch) .. this combination = fast, responsive, accurate and comfortable buttons.
(to make any button spring lighter, simply snip a little of it away with 'cutting pliers'    ... and if you make the mistake of taking a little too much off, you just stretch the spring out a little bit to increase the tension again)
Xiaou2
  • NOM NOM NOM
« Reply #6 on: January 04, 2016, 03:23:42 am »
Quote from: Xiaou2
 Yes, you can mod micros.. but they then will be too sensitive.   With Very light pressure, just resting on them... and you accidentally press them.
 It also still does not solve the impact issue either.   Your button will always bottom out...no matter how light you press, nor how careful you are.
 This is why the old school leafs beat micros in repetitive fire / rapidfire game.
 The leafs easily resist you resting on them, with decent pressure, without any fear of activation.
 Press to the middle of the button..  and it will activate.
 Instead of returning the button to the top.. stay in the middle, and lightly vibrate up and down.
 The leafs can easily be controlled to be open and closed as close, or closer,  than the thickness of a piece of tracing paper.
 No matter how you mod your Micros, that just will not be possible.
 As you make and break contact... you easily can keep your leaf button from hitting the very bottom.
 A leaf button has about 3x the vertical travel as a microswitch.  However, you only work in the middle range..  and you only have to move the leafs a mere onion-skin thickness, to make or break connection.
 A typical microswitch has to travel roughly 2 mm for it to fully depress,  and 2 mm to return.   Even if you were to make a mod to half that... its still 2 mm total.   A leaf button can beat that by about 200%.  2mm is like what?   200 onion skins?
I highly recommend getting a real leaf button, to see what you are missing.
Edit:
 Also, I have to say, that when I worked in the arcades for 3 years... the softer switches were the ones to break / fail the fastest.
There is always a trade-off.    Light spring, means that a spring will have very little tolerance range before it stops being able to work properly.  Over time.. springs lose some of their strength, as the metal becomes fatigued.   This is when the weaker springs start to break down... at first intermittently sticking,  and then fully unable to return the actuator.
 Leafs also can fail over time... but the lifespan is probably something like 10 to 15 years longer.  (in daily busy arcade hours,7 days a week)
Ive had micros fail in less than 2 years, in the arcade.
« Last Edit: January 04, 2016, 03:33:24 am by Xiaou2 »
RandyT
  • Last login:December 17, 2025, 10:08:10 am
    • GroovyGameGear.com
« Reply #7 on: January 06, 2016, 04:35:17 pm »
As usual, there are some truths to X's opinions, and there are also things which just aren't.
Old-style leaf buttons were very hard on the leaf switches.  Not a big deal in those days, where they were plentiful and inexpensive, and there were people who regularly took care of the games to replace/clean them when there were problems.  I have seen the leaf switches from those old buttons with the contacts completely ground off, due to the "feature" of not bottoming out (which they certainly still do if you push them all the way down.)
They also have a long throw, which is why you must adopt X's play style, if you wish to use them effectively.  If you play by "hovering" above the button until you wish to activate it, or like to hit them hard, there is enough extra travel that you might not care for them.  Every modern button uses a shorter plunger, and has a shorter plunger throw.
Installation of the old style leaf buttons is also a pain, compared to newer alternatives.  The switches are required to be spaced properly from the underside of the panel (how you do it is up to you) and it's not very forgiving.  Too close and it results in stiff actuation, and unnecessary contact wear.  Too far away, and the buttons will bottom out after a long travel to actuate them.  I have seen both of these undesirable implementations, even on one of my actual arcade machines.  It's these kinds of issues associated with the old buttons, which caused an entire industry to abandon them.  One can argue whether it was the right thing to do, but it doesn't change history, nor the reasons for doing so.
Not true.  What you describe is almost exactly what the adjustment screw of our Versa-Micro switches accomplishes.  It doesn't make it a leaf switch, but it does give the micro that specific adjustment.
As for softer microswitches failing faster (something which I have not seen substantiated,) you have to also ask whether the primary concern is that the switch is more enjoyable to use, or whether the sub-one-dollar switch lasts an extra year in an arcade environment.  I'd venture to guess that the choice would be for the former, for most players.
In the end, everyone will have different requirements, based on play style, the level of comfort they have in doing what's required to install them, budget, appearance, build limitations, ease of maintenance, etc...  Only the person building the machine, and ultimately using it, can know which variety will be the most suitable for any build.  The best advice is to get your "must have" criteria list written, and do some sampling from those offerings which meet it.  Otherwise, you may be relying on the opinions of others who have completely different criteria from yours.
Xiaou2
  • NOM NOM NOM
« Reply #8 on: January 07, 2016, 03:35:12 am »
 Everything wears over the number of presses.   This is typical mechanics.  These is rarely such a thing as an Indestructible part.  In fact, many parts are made to wear and be replaced.. to spare the more expensive parts..   such as the spacers inside a happs competition joystick.  If there were made of stainless steel rather than plastic.. they would wear the joystick base.. making it completely useless in less than a years worth of operation.   Making the spacer destructible, means only having to replace the .25 cent part.
 Also, most retro games were far more button intensive.  Rapidfire games were far more prevalent.. rather than use of auto-fire.  And while there is auto-fire in some classics..  it often gives the player faster fire rates if they choose to manually fire.
 This higher fire rate, would of course cause a lot more wear, far quicker.
 The leaf contacts were quite thick, but they also were replaceable, should they wear out.
 And yup, they can bottom out... but if used properly,  its easy to keep that from happening.  Equating to a far more quiet, comfortable, and enjoyable, experience.   (no more impact fatigue, and faster response times due to recovered energy)
 Ive seen microswitches of quality in brand new games.. fail in the arcade in a matter of 2 years.   They are far from an indestructible technology.
And when they do break... there is no real repairing them.  You just replace them.
 But wear is hardly as issue to the home game user... as they do not play a game 24x7,  as a busy arcade game would be played.   Ive seen ancient leaf buttons, work like they were brand new.   Then again, Ive seen them at their worst.. when the metal has finally fatigued, and they dont maintain their functional reliability.  But that again, isnt the issue.   The real issues are mostly to do with comfort, control, and desired reaction.
 False Statements.
 1)  This isnt MY style of play.   "Floating"  a leaf-button, was the intended way to play these games.   A widely known technique, that got lost over the years.
 2) You do  NOT  Hover over a button!   You simply rest your fingers on the button, and the spring compresses slightly.  Press a little more into it.. and simply maintain that "middle-area" of the button.
 Its the new hybrids that you have to hover above the buttons.. because they are so sensitive.. that your mere finger weight sets them off.   That means you have to actively engage your finger muscles to be constantly "ON" to hold them up.. so that they dont fall onto the button... least it go off immediately.  This actually causes far more strain, to have to hold your fingers up for long duration... and can easily lead to internal hand injuries such as carpel tunnel.
 Furthermore , "Modern" does not always equate to Better, despite the Egotistical Generational Hype that people want to believe.
 But tell me Randy... Do Modern Pinball machines use Microswitches or Leaf switches on their buttons?  (and assemblies)
 Ill spare the wait for others:   Yup.. thats right..  a modern Pinball machine, made in the year 2015,  still uses Leafswitches .. for both player buttons... and the assemblies.  And for really good reasons.   Not merely because they didnt want to swap out for Happs Micros.
 The plunger length has to be short for Micros.. because Micros are a fixed actuation distance.   Micros are designed for very reliable positive click functionality... hence, they are great for fighting games....   But Horrible for Rapidfire games.
 Plunger length however, does not denote activation speed, nor repeatable action.   That is denoted by how you use the button.
 And... even if you bottom out a leaf, you can stop it again at mid-level, on its upward return, for a faster quick repeat..  unlike a microswitch, which Always uses the full travel each time.
 Finally, as mentioned before..  Games using Micros tend not to have rapid repeating fire.   Hence, you have no need for a leaf.
But try to play Halleys Comet with a standard happs microswitch.   Even if you were really good at the game.. you couldnt last more than a few minutes without finger strain.   Wont happen on a regular leaf... so you could play 30 or more minutes with ease...
  Please site your sources to factual data proof,  at various companies,  to back up this statement.
 It wasnt hard for Leafs to be installed properly.  They came factory correct from the start.    If some lazy / time challenged  OP, swapped out a part for something incorrect, that he had "on-hand"  ... that was all his own doing.
 Its almost like saying that a particular assembly made for your car,  isnt worth installing... because a lot of clueless mechanics, botch the job up with incorrect mis-matched parts and poor installation practices.
 While Micros have an easier mounting solution... it doesnt really make them superior in certain applications.
 It also does not take a  Nasa Engineer, to install a leafswitch properly.   To say that, would insulting a lot of peoples intelligence.
 Anyone can admit, that leafs do have their drawbacks.   But it wasnt merely that the game industry decided to abolish them immediately... all at once.   Smash TV was released in 1990... with leaf swich joysticks.   The Simpsons was released in 1991, with leaf sticks.   And Im sure there may have been others past this year.
 Games started to change, most especially in the 90s.. when Street Fighter II hit.   Game companies started making less and less original titles.. and rather than care about skill levels in games,   they shifted their focus on "Continues".    There was no longer any care about the needed fire-rate to be able to survive a level.   Instead, you got autofire... and they just blanketed the screen in bullets..  knowing that most would just pop in more quarters to continue.    Thus, need for leafs were reduced to nothing, shortly after.
 Still, as said.. things like Pinball Machines kept using them... for the feel, and ultra quick reactions,  that they provide.
(As well as their uses in ball activated assemblies,  which needed specific weigh activation... as well as extreme durability (targets).
[/quote]
 False   I never said you couldnt adjust them.. but that you could not adjust them to perform like a real leaf.
 Hah.. now you are using my argument points, 'comfort'  ...but for Micros.    But lets just say this... after 3 years of daily arcade repairs.. 5 to 6 days a week.. (anywhere from 45 to 55 hours)..   in a busy mall foodcourt...   Ive seen a Lot of abuse and failure.  Ive seen and repaired the insides of more games and their assemblies, than one could imagine.
 Micros failing, was a very common occurrence.  Only taking maybe 3rd place to coin mech re-adjustments, and ticket feeder jams.
 Nobody noticed the comfort / pressure difference between light micros and heavier sprung micros... because they were not being used on Older games, such as the Rapidfire Leaf games.    The problem you speak of.. is when people try to use standard Micros to play games that never were designed for them.  Hence, they quickly fatigue from the heavy resistance of a non-tweaked or soft-click micro.
 Or just do your homework.  See what the original games used... and decide if you want the original feel, comfort, and superior performance... that the games were designed and built with.
 It can be as vast of a difference, similar in  comparison,  to a  Lamborghini... vs...  a Chevy Cavalier.   (specific controller advantages)
And or like trying to use a butterknife, to turn a phillips screw.   (incorrect controller type for game)
 One of us here has an Invested interest...  One does not.
 I feel sorry for having to "dis"  on the products that a vendor puts up for sale.    If I felt differently, then Id be raving and recommending... but alas,  I sadly just can not do that, in this case.
 I myself made mistakes many times in my assumptions and opinion..  especially with leafs,  in my past.   It took a little bit of new knowledge, and some testing,  to see the true light... and then eat my hat.
RandyT
« Reply #9 on: January 07, 2016, 01:32:47 pm »
Steve, changing a bunch of parts in an arcade machine as an arcade employee, doesn't make your opinions more valid nor qualified than anyone else's.
Some modern pinball machines did in fact use snap switches for flipper buttons.  Being an old school pinball aficionado, I didn't like it when I first played on one like this, but others didn't seem to mind.  Leaf switches have thinly plated gold contacts, and the rubbing back and forth on them, caused by allowing the leaves to be overextended (the property you like about them) wears through this plating relatively quickly.  Once this happens, they require cleaning much more often.  The design of the CLASSX buttons virtually eliminates this undesirable possibility, making the contacts last many times longer.  And yes, you can adjust them so you can rest your fingers on them, and float the switch.  I have an original Defender panel here which you cannot rest your fingers on without closing the switches.  This is with the factory switch spacers and buttons.  This is what I refer to when I stated (in previous posts on this subject) that installation methods are everything when it comes to the old buttons.  There were also more than one manufacturer, so they were not all alike with regard to the springs used and so on.  Depending on the switch spacers, and the variety, they can vary greatly from one game to the next.  Blanket statements about those old style buttons are not going to be applicable to all of them in every installation.
No one is saying that anything is "indestructible".  The difference between worn-out leaf switches and worn-out micros, is that the micro will probably cease to work.  The leaf switches continue to work, but become much noisier (electrically) and less reliable.  Designs which prevent the damage to the contact plating are far superior in this regard.
As for citing "proof" of spacing issues changing the dynamics of the switch operation, you only have to be somewhat mechanically inclined, and do a cursory examination of the part interactions.  If you had been around original machines long enough, you'd see that operators often made do with aftermarket parts when the originals became unavailable.  There were also a ton of conversions in the later years, and so-called "universal" parts were widely used.  The average arcade operator was not a mechanical engineer, nor did they have the time or inclination to become one.  If, after slapping these aftermarket parts into a game, they pressed the button and the ship fired, their job was considered done.
You'd be hard-pressed to find an old-style leaf button in any modern commercial machine.  It's simple economics.  I'm not sure you could find an employee who knew how to maintain leaf switches anymore, let alone find the parts to replace them when they went bad.  The fact is, most who have been active in this hobby for any amount of time, know more about controls maintenance and design than did the majority of actual operators and arcade employees.  We don't just replace parts....we fix them or design better ones.  I've been playing these games for 40 years, building them off-and-on for 25, and designing controls for over a dozen.  I've done more "homework" on the subject than you can probably imagine.
And then you quoted yourself saying something wasn't possible and directly thereafter stated you didn't say it, when I showed it was, and is something which has been available for some time now. So I don't even know where to go with that one.  :dizzy:
So I'll state this again.  The only way one will find the parts which will make one's "dream machine" a reality, is to do some sampling.  If there was one perfect solution to every problem, there wouldn't be the myriad offerings out there, which obviously are.  Folks who are stuck in the past will only progress if dragged kicking and screaming, and their opinions reflect this mentality more often than not.  It doesn't mean they don't offer points worth considering on occasion, but they tend to have an entirely different mindset than a modern-day builder, who likely has different criteria for their machine.
« Last Edit: January 07, 2016, 01:34:26 pm by RandyT »
Xiaou2
  • NOM NOM NOM
« Reply #10 on: January 12, 2016, 02:23:18 am »
There is no point in wasting time arguing with the majority of what you posted, because you have said nothing worth reply.   Pretty much all of your arguments are a sales pitch... based on your poor ideals, of what you think is innovative.   Sorry.. but you failed.   Admit it, and move on.
 Again,  you try to lump me in as an "old" guy.. whos set it his ways.   Id dare say Im far more open minded and eclectic than you.
 In fact, I initially did not care for leafs,  until I realized I was using them improperly.   There are many tech innovations that I love, and I continue to keep up on new things... from computer tech, to entertainment tech, to new scientific discoveries...
 I embrace new technology, and Ive worked with, and On, new technology.. as a computer tech.
 All of that said, means squat.. when we are talking about Classic Arcade Games.
 Age has NOTHING to do with the benefits of a real physically restricted 4 way joystick!
 Nor the benefits, comfort, and response of a leafswitch.
 You are like a Modern speaker designer... whos trying to pop out some tall narrow tower  (small form factor),  particle board + plastic, pile of poo... and pass it off to the dumb consumer, as a $3000  masterclass work of art..  and as a technologically superior device...
 When in fact.. anyone with any background and experience with high quality, high fidelity speakers... sees right through the marketing.
 Their much older, big honking speakers from the 70s,  will blow the modern garbage away, by a factor of 11.  In near distortion free clarity, Massive 3d soundstage, deep punchy musical bass  (not muddy ported farts),  and pure raw power output.
 This is not about customers whom want smaller speakers...  Its about is trying to convince everyone that older speaker designs are inferior.. (big, bulky, powerhungry, ugly, and old... and any other type of BS negative jab)  and not what they really want.
 When in fact,  hearing both side by side... properly powered, correct placement, and good detailed source material... and most would immediately tell the difference, and choose the older speakers... even if those speakers were twice the cost of the new.
 Rather than to try to drastically change the tech... its far better to inform people of the proper use of the tech, with the benefits and pitfalls of the tech... and allow people to decide if those align with the product that they are seeking... rather than get stuck with something that doesnt work well for their intended purpose.
 Finally, Id love to hear what "Modern" Pinballs used Microswitches for the players buttons !!!   Ive seen many hundreds of Pinball machines in person... at various collectors homes (entire basements filled with Pins of all eras),  in the arcades, at auctions, doing home repair work, and at many massive Pinball shows!  Not ONE machine Ive EVER encountered, in over 20 years, have I seen Microswitches used for the Players buttons!    Site Proof.
 *BTW - You do know that New pinball machines have been, and Continue to be made this very date... right?   And None of them have Micros for the flipper buttons.    * Z * E * R * O  *      Not even the Remakes, nor the scratch built DIY Machines.
 Also, your statement touches on the idea that this is my "Opinion".   When in fact, I am stating straight up facts, based on Physics: material properties, and total mechanically designed application.
 Physics does not get "Old"...   But the miracle snake-oil pitch, does.
« Last Edit: January 12, 2016, 02:42:57 am by Xiaou2 »
Ginsu Victim
  • Comanche, OK -- USA
« Reply #11 on: January 12, 2016, 12:49:01 pm »
Sorry, I trust Randy more.
RandyT
« Reply #12 on: January 12, 2016, 12:58:20 pm »
I think the word you were looking for was "eccentric".  Your posts certainly demonstrate none of the open-mindedness you claim to possess, regardless of the topic being discussed.
*edit*    still looking for the machine...  It appears that the one I posted didn't have them as stock, so it may not be it.  But you don't forget playing a pinball machine with microswitch buttons.  Will update when/if  I find it.  It may very well be that one of your seasoned operator bretheren decided to replace the leaf assemblies with microswitch buttons when the contacts started getting fluttery.  Possibly another case of "if it works when the button is pressed, the job is done"
*edit 2* It may also have been a Data East pinball title I was playing.  You can see the microswitch button assembly in this thread, and a part reference here.
There's a difference between a "sales pitch" and outlining the fundamental design philosophy of something I believed in strongly enough (and still do) to invest ~$10,000 of capital we really couldn't afford, in order to make it available to folks in this community.  Fortunately, the "word of mouth" advertising of many thousands of happy users, has us in our 4th large production run.  It took about 5 years to happen, but we are finally just past the "break even" point, and more are going out the door every day.  It wasn't unexpected, as this is the route most of our innovations take in such a small market as ours.
You wish to believe that all of those very happy users are victims of "salesmanship", simply because you can't seem to let go of a somewhat ill-concocted, preconceived notion that nothing can be as good as what you yourself possess and use.  I'm happy to say that you are in a very tiny minority.
Attempting to stifle innovation, as seems to be the goal of most of your "contributions", does more harm than you can probably imagine to our small community.  Fortunately, the more open-minded among us who are willing to give these innovations a chance, reap the benefits of them and quite often, come back for more.  This leads to new innovations and the furtherance of our hobby.  I'll also note that many of our past innovative moves forward are now considered mainstay, and copied by others.
Strangely, you seem to take exception with my advice telling others to try the myriad offerings out there, to find what they like best.  I think that says everything.
« Last Edit: January 12, 2016, 03:02:08 pm by RandyT »
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #13 on: January 12, 2016, 09:00:50 pm »
See, that's the Xiaou we've come to know.
Steve -- it's painful to see you try to argue facts when you don't actually have many. It's not like you're kowal or KevSteele breaking out the calipers and measuring everything to the millimetre -- handling things in a scientific manner. Hell, Randy's actually designing,  building and selling stuff.  He's done the measuring. Done the legwork. Done the math. He's proven himself. Dismissing him as you do makes just makes you look like a lunatic.
Randy's absolutely right about spacing with leaf buttons and switches. There is a reason why there are four (or it is it 5) different sizes of leaf button spacers in my Big Box o' Buttons. You need to properly match the button height, control panel thickness and spacer height. Otherwise you end up sliding the contact, ---fudgesicle--- them up and get less than decent response. There is no such issue with buttons where the switch attaches directly to the button and the plunger depth is controlled, like a normal microswitch-based button. This is control panel design 101, so you're not particularly credible with that denial (and then there is the whole issue of the extra space taken up under the panel by the damned switches).
Having said that, leafs are the best button controls. Because controls are all about feel and they feel best to me. No dick measuring required.
« Last Edit: January 12, 2016, 09:02:51 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
« Reply #14 on: January 13, 2016, 12:51:50 am »
What is the leaf-to-microswitch ratio when it comes to ---Deutsche Frankfurters---?
Jakobud
  • Last login:December 09, 2025, 12:11:34 pm
« Reply #15 on: January 13, 2016, 02:39:49 am »
I rarely lurk on these forums anymore but its funny that after like 10+ years its still the same folks having internet arguments with each other :-D
Ginsu Victim
« Reply #16 on: January 13, 2016, 09:52:00 am »
I pop in here occasionally and, yep, it never feels like the wrong place.
lilshawn
  • Last login:December 15, 2025, 02:24:06 pm
« Reply #17 on: January 13, 2016, 10:16:17 am »
here is the answer...
buy a clear button... like what you'd want for illumination...
then just buy a bunch of different colored cherry D4 series switches to try in them. if you want a positive snap action...maybe a red or purple....something a little soft and squishy and quiet...green something rediculously loud so you know when it's been clicked...red or black.
all the switches have an actuating force some are harder than others. from less than 45 cN to over 150 cN.
...and so on. then just try various switches with your button until you find one you like that actuates how you like, and sounds how you like...then buy a pile of them for your panel.
 :dunno
dropper
  • Last login:April 20, 2017, 09:22:07 pm
« Reply #18 on: January 15, 2016, 04:46:56 pm »
lilshawn,
You should watch out, that seemed like a reasonable response to the question asked, which is where the thread was going.
Keith
(Long time lurker here...)
05SRT4
« Reply #19 on: January 15, 2016, 07:33:06 pm »
I hope OP logs back in to get all this rich information.
lilshawn
« Reply #20 on: January 15, 2016, 07:36:31 pm »
Keith
glad i popped your cherry with a tidbit of info so fantastic... you absolutely had to create an account and login to comment.  :cheers:
Xiaou2
  • NOM NOM NOM
« Reply #21 on: January 21, 2016, 03:02:22 pm »
 So, you try to attack me personally again.   What a surprise.    Lets just say that I have plenty of people whom know me personally, from all age ranges, spanning multiple fields  ... and None of them would call me "Eccentric", Period.
 In my deeper past, I wasnt very always as open minded.  But time and experience can change a person.
 And yet another personal attack.  Poor Randy.  I feel sad for someone who feels so inferior inside... that they have to resort to attacking others to try to prop themselves up.
 I was never a route based "OP".   I was an arcade manager at a dedicated store.    And my repairs and restorations,  were done with a very high level of accuracy, passion, and pride.   I didnt bubble-gum things in place, nor keep half-functional games up..just to keep up figures / appearances.
 Furthermore, the majority of the collector friends that I have,  have that same level of passion and expertise.   Owning entire basements of machines that were restored to pretty much factory new status...or better.
 So you may have found a rare-exception machine.. or rare conversion kit for this rare machine.  Bravo.
 Now lets talk about Reality...  Every other Pinball MFG has and will continue to use Leafs in their flipper buttons.  This includes the 3 big names currently selling machines brand new, at 5 to 8 grand a pop...  as well as newly made creations from individuals.
 Anyone whos into Pinball is chuckling at the laughable Ignorance.
 So, you get a bunch of clueless people buying a product that they THINK will be what they are looking for.   Ive seen plenty of said "happy People"  ...Wise-Up.. and cease said modified product use... switching over to Original designed parts.  Used or NOS.
 The amount of money and investment does not make me feel any sympathy for your Egotistical attitude and poor judgement on design changes.
 Whats amazing... is how you almost try to play both sides of the field.    You promote a Leaf-Stick...  then you almost try to bash leaf technology.   When ultimately,  you simply never really fully understand the original use and design to begin with.
 It would be one thing... if you made the connection,  and then were honest about it.. hopefully altering products to match the new knowledge and information.    But you dont want to pay for your misguided mistake.   You would rather others suffer shelling out for expensive lackluster controls...  that dont match the original intended use and desired properties.
 Trying to provide proof of being "Right"  by the number of Ignorant purchasers... is again sad and laughable.   Its like the person whom invented a hopelessly unworkable / flawed   Infomercial product...  and claiming their device must be the best, because its sold to many thousands of easily fooled zombies.
 How happy were these Zombies after the said infomercial product failed then in some way, that was cleverly hidden from them?
 I guess you didnt read the part when I said that I initially hated leafs..  due to my own former misunderstanding of them?!
Or the previous stories of how I stupidly converted a few classics at the arcade to use micros... and Immediately realized my error.   Part due to backlash from people.. and part due to my own personal realizations with a few plays.
 Nah..  you read it.   You are just trying to paint me with a false picture, to fit your agenda.
 And as for your Pathetic "Minority" comment..  Id love to see your factual data collected from the millions of arcade fans, ops,
collectors, pinball owners, restorers, etc.    Ohh wait.. you are going to refer me to your brainwashed infomercial purchasers from your small market of clueless purchasers...   yeah, umm,  forget it.
 The reality is that the people learn quite quickly..  and as such, parts like Wico 8 ways, flew out of ebay sellers hands, at insane rates... even if they were used and abused.   That people still buy used leaf buttons on ebay,  and or strip them off used control panels.   Daily.   In the hundreds.   Ebays arcade control sales, trouncing your customer sales,  100,000 to 1.
 Theres a whole world of people out here... that you obviously are clueless about...
 Or are you?   You invested in the Dom~8 stick...   (After first showing a generic japanese joystick leaf-hack)
 Funny,  because most of my designs and ideas,  are completely innovative and new...
 No,  I dont Stifle innovation.   However, I do correct improper assessments and steer people away from flaws in their plans / thinking.
Only thing is... you can only help others if they are posting ideas first...  rather than posting pictures of a finalized flawed control panel /device.
 And nobody can seem to help an Ego-Maniac...  because such people are so frail.. that they cant take any criticism...
So they instead, just try to attack the character...  rather than deal with the real issues.
 Passing of generic hacks isnt really innovation either.  Its being lazy, and ultimately, taking advantage of others.  It shows a lack of passion, quality, and true connection to the hobby, and its people.   It misleads many whom have limited funds...  who get burned when they realize that they got a bunch of garbage that doesnt work for well them.   Now that, coupled with factual ignorance on such controls... is actually Damaging to the hobby.
 I cant wait till someone whom actually cares, and is actually well informed, isnt an Ego-maniac ... puts out high caliber replica parts...   and we watch all the Hack-Sellers go bust.. and or scramble to try to copy and or catch up...
 You can try to attack my character all you want...  but you cant dissolve the power of the truth.  People will wake from their ignorance soon enough.
« Last Edit: January 21, 2016, 04:12:29 pm by Xiaou2 »
RandyT
« Reply #22 on: January 21, 2016, 03:32:16 pm »
Steve will be ......Steve.
Ginsu Victim
« Reply #23 on: January 21, 2016, 03:36:09 pm »
Unfortunately, you're way too comfy and sleeping deeply.
Oh, thank God you didn't bother with a Xiaou2-length reply. I have three times the posts he does, but I'll be damned if he hasn't written ten times more words.  :lol
« Last Edit: January 21, 2016, 03:40:25 pm by Ginsu Victim »
CheffoJeffo
« Reply #24 on: January 21, 2016, 03:40:55 pm »
Steve -- take your meds. You're far crankier and more delusional than usual and that always gets you into trouble. You claim that you are being attacked personally, but it is you calling load of people here clueless. There is no need to attack your character because you are displaying a severe lack of such.
As I said before, Randy's facts are more solid than yours (no matter what you say or claim from your brief period doing scut maintenance at an arcade) and I haven't seen him say anything too far from reality.
Working: Not Enough
Projects: Too Many
Progress: None
Xiaou2
  • NOM NOM NOM
« Reply #25 on: January 21, 2016, 03:54:58 pm »
 There is no delusion.   I am picking at his product,  and lack of understanding of the intended workings of leaf buttons.
While he is trying to pick apart ME.   Not the argument.   That is Fact, not delusion.
 Your quote makes no sense.   Randys Facts?!   He is presenting Opinion.  His lame Factoid of the old Dataeast using a microswitch hardly qualifies to defeat my arguments.   MODERN PINBALL machines are still using Leafs.   And for good reasons.
 And while I agree that the mounting with leafs isnt exactly Optimal...  that does not change the fact that they still perform their function superior to these Hacks.
 Mechanical knowledge and skills do not always equate to higher truth.
Engineers make horrible assumptions, theories, and mistakes,  on a regular basis.
 The difference is... many are willing to correct these mistakes... where as others choose to try to hide and or defend them.
CheffoJeffo
« Reply #26 on: January 21, 2016, 04:07:44 pm »
And still others "end up with one of the most ridiculous pieces of crap ever conceived."
Working: Not Enough
Projects: Too Many
Progress: None
Ginsu Victim
« Reply #27 on: January 21, 2016, 04:11:45 pm »
Uhh,   so what you are really saying... is that you are Willfully Ignorant.. and you basically post a bunch of Useless garbage
At least I know my posts are garbage. You haven't caught on yet.
Now apologize to the new guy for revealing yourself this quickly.
« Last Edit: January 21, 2016, 04:13:41 pm by Ginsu Victim »
  • Last login:Today at 02:18:20 pm
« Reply #28 on: January 21, 2016, 04:20:39 pm »
lilshawn
« Reply #29 on: January 21, 2016, 04:24:35 pm »
lilshawn drills pilot holes to screw down a handle for when this thread gets whisked away to post hell.
Token
« Reply #30 on: January 21, 2016, 04:47:03 pm »
This is all your fault, yots.
Xiaou2
  • NOM NOM NOM
« Reply #31 on: January 21, 2016, 05:16:28 pm »
 Am I taking med? and or what kinds of meds?    There are legal actions that many take, to defend against false information...
 This is a personal attack.   It basically points to the idea and or assumption,  that I hang around with people of low caliber natures.  And as such, paints me to be such a person myself.
 Hence the term  "one of my bretheren".    Else, he would not have included ME into that statement at all.
 There is a difference between saying people are  uninformed, ignorant, clueless.   These not direct attacks.  And in many cases, its complete truth.
 There are in fact many things I am clueless and ignorant about.   Nobody knows it all.   And so that is not an offensive thing.   But to try to undermine and paint someones character...  that is in fact, a personal attack.   Its typical of Narcissitic abusers to both attack in indirect ways.. as well as to trivialize what has been said.
Randys facts?!   lol    Facts do not belong to others.    Facts are universal...  and they are 100% certain / true.   Hence,  you cant have "less-solid"  facts.
 3 years worth of 8 to 10+ hour days,  in a busy food court location,  is nothing  "Brief".    In one mere week, nightmares of imaginable proportions can and did often take place.    Furthermore,  I was not merely the repair tech... I was managing the place from top to bottom.  Paperwork, ordering, staff, bank deposits, and everything else under the sun.
 But, as Narcissists often do... you try to Trivialize others.  Belittle them.
 Its more than just hands on repair experience with nearly every know video game controller.   Im a collector and restorer.   Ive restored many machines over the years,  and Ive worked as a private tech, on others video games and Pinball machines.
 And its built off of a full life of passion in video games.  Play. Testing.  gathering pics and information, scanning artwork,  and more.
 Your edited post about Kevsteel and Kowel,  was funny.
 You dont need calipers to understand the mechanics of a lever, for example.
 I dont think Kowel even plays much besides fighters and bullet hell shumps...  which hardly qualify him in matters of classic leaf games.
And Kev..  his feedback about Leafs were equally lacking in understanding of their functionality...  despite his documented precision data measurements.
 Which of course, shows how easy it is to overlook something critical... no matter how Intellectual you are.
And how data, even lab data... can often be completely corrupt, distorted, or wrong.
Steve -- this thread is about what appears to be the best Wico replacement I have seen. Randy did that.
 Well, I have not just "Seen"  these.  I have one.   Its not a replacement.   I wouldnt even consider using it in my Asteroids Deluxe.
Its that bad.
 Im not impressed with hacks that dont fit the bill...  and Ive every right to say so,  and why.
Until my health and wealth fall... I owned 4 arcade machines, and 3 pins.   Id say that is what a great potential customer looked like...
You, OTOH, built something described as "there is ---steaming pile of meadow muffin--- like this that you have to take tainted meth to come up with" which applies with equal favour to your shoe analogy.
 You Narcissists love to stick together.  Though, I imagine the conversations are very one sided... as you all just talk to yourselves... ignoring each other...
 I dont sell personal prototypes... nor state that they are the best thing since the invention of the wheel.
I put my elder proto example up, as my own solution to my lack of controller compromises... and my limited space, tools, and funds.
 Funny enough..  it was my drastic change in views about leaf controls,  that ultimately made me scrap my proto.
« Last Edit: January 21, 2016, 05:26:24 pm by Xiaou2 »
CheffoJeffo
« Reply #32 on: January 21, 2016, 05:28:07 pm »
OK ... the meds comment was out of line. Mea Culpa.
 Well, I have not just "Seem"  these.  I have one.   Its not a replacement.   I wouldnt even consider using it in my Asteroids Deluxe.
Its that bad.
I wouldn't put one of these
in one of these
either.
Read before you post -- you're getting your threads confused.
Working: Not Enough
Projects: Too Many
Progress: None
Xiaou2
  • NOM NOM NOM
« Reply #33 on: January 21, 2016, 05:36:02 pm »
No, Im not.   Randy was in fact excited and kind enough to send me one of the leaf buttons.
 The recent Dominus8  looks far better and more classically accurate,  replacement for the Wico 8 way leaf joysticks.
 However, I cant really confirm that,  because I have never felt them in my hands.   Mechanics wise however, it does look good.
 The button though... is not even close to the desired feel and control.
 Too bad,  because it could use all new shinny buttons...
Xiaou2
  • NOM NOM NOM
« Reply #34 on: January 21, 2016, 05:39:02 pm »
Ah...  Love it.  X2 is right, the rest of the universe is wrong.  At least according to him.
 So by "Universe"...  you mean,  a few typical Narcissist posters,   many of which do not own a leaf button... nor understand its correct operation?
 I guess you are correct then...
   :laugh2:
Ginsu Victim
« Reply #35 on: January 21, 2016, 05:42:30 pm »
Who are you talking about with that post? I own them, Cheffo owns them, Randy owns them....
CheffoJeffo
« Reply #36 on: January 21, 2016, 05:44:02 pm »
But you quoted *ME* and I was talking about a joystick with actual leaf switches. Somehow you figured that I should have been talking about a levered button. Those are not the same things. You can't haphazardly ascribe new meanings to what was actually written (e.g. a fact) because you want to argue about something else.
The sad thing is that you won't find a bigger fan of leaf buttons and Wico sticks on this board. I have boxes of both. But I can't say "Xiaou's right" because you rant all looney and tooney about things that aren't real.
Working: Not Enough
Projects: Too Many
Progress: None
CheffoJeffo
« Reply #37 on: January 21, 2016, 05:47:20 pm »
Cheffo owns them
Actually, it's more of a mutually supportive patronage arrangement. I'm progressive that way.
Working: Not Enough
Projects: Too Many
Progress: None
Ginsu Victim
« Reply #38 on: January 21, 2016, 05:48:28 pm »
RandyT
« Reply #39 on: January 21, 2016, 05:51:43 pm »
Steve, the only reason you even have one (two actually), is because I sent them to you for free (my error.)  You immediately started criticizing it, most likely because you had no idea how to properly adjust it to do what you wanted, and/or can't seem to get past the fact that they are not the same button as those made 35 years ago.  You have some very "set in stone" ideas, based almost entirely on your personal preference, and it's clear that absolutely nothing will ever change them.  It really not worth trying anymore, so there's nothing left to do but direct folks to explore what you have done, so that they might accurately consider the source.
There are thousands of folks who have moved to using the CLASSX buttons, after having used others on the market, and I haven't had a single complaint about them (other than you).  Quite the opposite, in fact.  These are the people I take my queues from, and whose opinions really matter.  Walls of text, full of rants and insults directed toward those people for enjoying something different from your ideal, says something very important about you.  I'm happy to let others decide what that something is.
