Author Topic: Gas springs for control panel lid?  (Read 4676 times)
TurboJugend
  • Last login:July 26, 2016, 01:44:53 pm
« on: December 30, 2015, 11:25:08 am »
I'm *finally* about to start working on my first cabinet.  Been dreaming about this for years.  Anyway, I was thinking about installing some gas springs like these http://amzn.com/B00GWAI7C0 on the lid to the control panel.  Just wondering if anyone here has done this and how they worked out.  This will be a pretty standard 2 player CP.  The gas springs are rated 22.5 pounds.  Seems like that would be sufficient, no?  I searched the forum and found a few mentions of them, but no real feedback on how happy people were with them.
wxforecaster
  • Last login:February 28, 2019, 01:19:24 pm
Re: Gas springs for control panel lid?
« Reply #1 on: January 02, 2016, 02:01:36 pm »
I would think these should work just fine. Curious what other hinging methods people use to lift their CPs. I planned on adding a lock to mine to keep grubby hands out.
TurboJugend
« Reply #2 on: January 02, 2016, 05:24:07 pm »
I went ahead and ordered a pair.  Going to try them out.  Although, I thought of one possible problem.  I'm not sure if these can be separated from the lid easily in the event I need to remove the CP top.  They might need to be unscrewed from the wood.  That's not ideal.  We'll see.
jennifer
« Reply #3 on: January 02, 2016, 11:55:05 pm »
   You may want to use a steel carrier frame for that, They are under pressure and will tear the pins loose on wood structure (don't ask how I learned that).
eds1275
  • Rock and Roll!
« Reply #4 on: January 05, 2016, 05:04:53 pm »
My control panels fit between the sides of the machine and have a bottom lip and the top. Makes it easy to service since I don't have much to take apart!
https://www.facebook.com/photo.php?fbid=10150356541855246&l=9fdba2a0a4
8BitMonk
« Reply #5 on: January 05, 2016, 06:31:15 pm »
I used those in my Super Mario Strikers build for the back door and was happy with them. The door was fairly heavy, 1/2" MDF, a mounted cpu etc. and no problems with the weight. The pressure seemed to be different between a couple of the 4 that I bought, one was really weak. Not sure if this was a defect in one or what but I just used the two that were similar. Really good value for the price, no complaints.
« Last Edit: August 07, 2017, 07:58:13 pm by 8BitMonk »
