Author Topic: 2nd PSU?  (Read 1179 times)
JudgeRob
  • Last login:July 13, 2024, 10:00:33 pm
2nd PSU?
« on: November 24, 2015, 09:44:51 pm »
I was thinking of using a second ATX PSU to drive LEDs, etc.  It seems like extra lights and such might draw too many amps off the poor PC PSU.  Anybody have problems with PSU burnout from too much power draw of a singular PSU?
mgb
  • North East, US
Re: 2nd PSU?
« Reply #1 on: November 24, 2015, 10:09:01 pm »
If the PC psu can handle it, amp wise, there's no big deal but it doesn't hurt to dedicate a psu to the lights and what not.
There are many cheap psus available online in 5volt, 12volt, etc.
If you choose to use an old atx pc psu you may have around, just remember that you will need to jump the power start wire to ground. This is the green wire at pin 14
JudgeRob
Re: 2nd PSU?
« Reply #2 on: November 24, 2015, 10:58:19 pm »
I have an extra one I might use just to prolong the life of the one in the PC.  I guess it depends if I need more than just a few LEDS.  I'm not sure yet.  One thing is, although LEDs are pretty efficient, now that they are all superbright and RGB, they suck up a bit of power.
The other thing to remember is not only to jump the wire, but there also must be a certain power draw on the PSU or it will shut off.  I had that issue on another LED project and have to use a power resistor just to keep the PSU on!
Thanks dude.  8)
paigeoliver
  • Awesome face!
Re: 2nd PSU?
« Reply #3 on: November 24, 2015, 11:41:31 pm »
You don't need two power supplies for LED lighting unless you have gone far beyond the realm of arcade game and into the realm of 1980s Vegas casino signs.
« Last Edit: November 25, 2015, 01:08:58 pm by paigeoliver »
ventrra
  • Last login:April 10, 2020, 02:29:29 pm
Re: 2nd PSU?
« Reply #4 on: November 25, 2015, 01:07:53 pm »
You don't need two power supplies for LED lighting unless you have gone far beyond the realm of arcade game and into the realm of 1980s Vegas  Casino sign.
Ooh. A 1980's Vegas Casino themed arcade machine sounds awesome!  ;D I wonder if anyone has had the nerve to make one? ???
JudgeRob
Re: 2nd PSU?
« Reply #5 on: November 25, 2015, 07:26:07 pm »
I thought about it briefly, but I don't think I could pull it off.  I've got a few hundred RGB LEDs in my TV room though!  I power those with an ATX PSU.
TopJimmyCooks
Re: 2nd PSU?
« Reply #6 on: November 25, 2015, 10:06:21 pm »
I have two in the switchcade machine- the pc has a dinky sff that came with the case, while the rotation motor and lights, etc. are on a $14 crap ATX psu.
JudgeRob
Re: 2nd PSU?
« Reply #7 on: November 25, 2015, 10:53:41 pm »
Yeah, I think introducing motors with torque, etc., would certainly warrant some consideration for a 2nd PSU.  Esp if one has some bad-ass video cards sucking up juice.
