Author Topic: Bad crimper?  (Read 3351 times)
fablog
  • Last login:January 04, 2026, 04:27:15 pm
Bad crimper?
« on: November 19, 2015, 07:44:10 pm »
I bought this crimper today and the vendor said it was OK with 22-24 AWG.  But I don't think so after to try with an arcade paradise Il led wire and a 0.1" housing. What do you think?
« Last Edit: November 19, 2015, 07:46:08 pm by fablog »
jennifer
Re: Bad crimper?
« Reply #1 on: November 19, 2015, 10:10:38 pm »
   I cant believe its bad, Even the cheap ones will squeeze a crimp, For multiple however you might want to wear gloves so your hands don't get sore.
fablog
Re: Bad crimper?
« Reply #2 on: November 19, 2015, 10:17:04 pm »
OK then I don't have a good technique. I need more practice :)
jennifer
Re: Bad crimper?
« Reply #3 on: November 19, 2015, 10:42:55 pm »
   There are some really good sites on the subject, (Molex has a really good comprehensive overview), Surprising complicated for such a simple thing,  But at the end of the day yes, its a easily learned skill.
Re: Bad crimper?
« Reply #4 on: November 19, 2015, 10:59:16 pm »
There's a nice YouTube video if I remember right. ..
Trick is to clip down the tabs to just the amount you need to make it around the wire.
ChanceKJ
« Reply #5 on: November 20, 2015, 12:23:02 am »
« Last Edit: March 19, 2021, 03:55:00 am by ChanceKJ »
jtslade
  • Last login:January 22, 2026, 03:19:42 pm
  • Keep it looking originallish!
Re: Bad crimper?
« Reply #6 on: November 20, 2015, 07:52:53 am »
Ms. Pacman Original Cocktail with Non destructive mod to Groovy Arcade Linux with All 4way Vertical Cocktail capable 2 button or less games.
Neo Geo MVS Mame Cab Running Hyperspin, 25" Nanao Arcade Monitor, Mini-pac, ATI Radeon HD 4850 (ATOM-15), IL 8 Way Euro-Sticks from Paradise Arcade, Win XP 64bit, and tons of other junk.
fablog
Re: Bad crimper?
« Reply #7 on: November 20, 2015, 08:07:47 am »
Chance, I'll post a pic this week end but I'm a beginner in crimping.
Question for all: what means the 24 number in the 22-24 AWG dimension?
BorgDog
Re: Bad crimper?
« Reply #8 on: November 20, 2015, 04:28:45 pm »
20$ and done
http://www.twistedquarter.com/index.php?main_page=product_info&cPath=71&products_id=975
Or same one from harbor freight for $5 less, also the one groovy game gear sells is the same one:
http://www.harborfreight.com/ratcheting-crimping-tool-97420.html
My Projects:
ChanceKJ
« Reply #9 on: November 20, 2015, 04:48:00 pm »
« Last Edit: March 19, 2021, 03:48:55 am by ChanceKJ »
  • Last login:Today at 05:02:13 am
Re: Bad crimper?
« Reply #10 on: November 20, 2015, 04:53:44 pm »
AWG = American Wire Gauge
22 AWG = 0.0253" diameter
24 AWG = 0.0201" diameter
+1 on ratcheting crimpers.
You can also get crimp dies that fit the Harbor Freight handles from Pimfg. (236 or 336 series dies)
Pin crimp tool (HT-336-FM with an HT-236-2U crimp die for 0.084" pins)
jtslade
Re: Bad crimper?
« Reply #11 on: November 20, 2015, 05:42:18 pm »
Harbor freight rocks
vwalbridge
Re: Bad crimper?
« Reply #12 on: November 20, 2015, 05:50:17 pm »
Sure, as long as you can get over the stench of vulcanized rubber coating everything in the store.
fablog
Re: Bad crimper?
« Reply #13 on: November 20, 2015, 06:09:28 pm »
Thx for the explanation
fablog
Re: Bad crimper?
« Reply #14 on: November 20, 2015, 08:55:38 pm »
The best pics I could take. I don't know if this crimp is OK. What do you think? My tool  really isn't easy to use but it cost me only 20$. I'm sure a 50$ crimper is much better but for only 48 wires...
Re: Bad crimper?
« Reply #15 on: November 20, 2015, 09:00:01 pm »
Looks pretty darn good, is it pretty sturdy?
Well placed zip ties for strain relief and your golden.
ChanceKJ
« Reply #16 on: November 20, 2015, 09:06:49 pm »
« Last Edit: March 19, 2021, 03:36:40 am by ChanceKJ »
fablog
Re: Bad crimper?
« Reply #17 on: November 20, 2015, 10:00:19 pm »
It's sturdy yes but my fear is the wire isn't in contact with the connector. I did a test of the led and it's alive but in test mod I see only purple, blue and red colors, not green. Is it normal or surely a wire isn't well soldered?
fablog
Re: Bad crimper?
« Reply #18 on: November 20, 2015, 11:19:44 pm »
I found the answer alone, I soldered another one it function with all the colors. I'll do the first one again later. I crimping the other ones first :)
jtslade
Re: Bad crimper?
« Reply #19 on: November 20, 2015, 11:56:23 pm »
Harbor freight sucks
Sent from my iPad using Tapatalk
fablog
Re: Bad crimper?
« Reply #20 on: November 21, 2015, 09:27:17 am »
I learn something important: don't crimp too much those little wires and buy a good crimper.
More than 2 hours to crimp and crimp again 6 buttons, it was much easier to laminate MDF :)
It should be quicker for the next 6 buttons ahahah!
« Last Edit: November 21, 2015, 09:28:56 am by fablog »
fablog
Re: Bad crimper?
« Reply #21 on: November 21, 2015, 06:05:03 pm »
I finally understood why I was doing and doing again the same crimp. The connector the salesman sold me is with a diameter to much high.   I solve the problem bending the wire to get a 2 ply. Chance you gave me the right information but I couldn't find those exact molex models in my place.
kowal
  • Last login:September 17, 2023, 02:02:16 am
  • Suzo 4ever
Re: Bad crimper?
« Reply #22 on: November 22, 2015, 04:28:50 pm »
I have this crimper and this model can not properly tighten the connector PH/DuPont/ Molex 2.5-2.54mm
criper has no heart-shaped jaws
DuPont crimp tool is still protected by patent, and all substitutes do not work correct
only this work fine
I use original Berg HT-102
http://www.ebay.com/itm/BERG-HT102-CRIMP-TOOL-/291619008362?hash=item43e5d8ef6a:g:2hsAAOSwkZhWS912
and this is not terrible but still far from ideal
http://www.ebay.com/itm/Dupont-Pin-Crimping-Tool-2-54mm-3-96mm-KF2510-28-18-AWG-Crimper-0-1-1-0m-389-1-/111816590574?hash=item1a08c9c4ee:g:8uoAAOSwv0tVSOaU
too heavily crushes connector, and have jaw with double heart-shaped (orginal Berg have only heart on one side look on this auction 2rd photo, show correct crimp  http://www.ebay.com/itm/25pc-Dupont-pin-with-Wire-24AWG-1007-VW-1-80-FT-1-90-UL-CSA-L-25cm-Red-/130668148223?hash=item1e6c6db5ff:m:m9sLsrwr-x-lGT3Q-7L1B3Q) one side - heart, next side - circle)
« Last Edit: November 22, 2015, 04:41:39 pm by kowal »
