Author Topic: PCB soldering problem  (Read 1286 times)
grippie
  • Last login:February 28, 2025, 10:00:46 am
  • Genesis Does
    • Optimus Meatron
« on: November 03, 2015, 01:16:38 pm »
So I broke apart my game gear pcb for my portable pi project, and the d-pad isn't functioning properly... I think.
If i take my multimeter and check for continuity by putting black on the common ground, and touching red to the wires i get weird results.
For up. Left. Right.  It zeroes out the multimeter which doesn't seem right. If i check down, it doesn't zero out until i press the pad down to complete the connection.  The right side buttons seem fine, only zeroing out when the button is engaged.
Any ideas? The pic shows the solder points that I'm checking with the multimeter.  Pic is from the adafruit project that i based my cuts on.
grippie
  • Genesis Does
    • Optimus Meatron
Re: PCB soldering problem
« Reply #1 on: November 03, 2015, 01:18:39 pm »
Here is my actual work but the glue obscures the solder (which i checked and isn't bridged)
lilshawn
  • Last login:December 15, 2025, 02:24:06 pm
« Reply #2 on: November 03, 2015, 02:26:00 pm »
can you verify the "ground" is in fact common to all the pads and not a seperate line in itself?
Slippyblade
« Reply #3 on: November 03, 2015, 03:21:57 pm »
Yeah - gonna agree here.  Sounds like the ground is split up, which isn't uncommon.
  • Last login:Yesterday at 12:23:29 pm
« Reply #4 on: November 03, 2015, 03:56:41 pm »
Still, it sounds like the top 3 are grounded out.
Could we see the flipside?
grippie
  • Genesis Does
    • Optimus Meatron
« Reply #5 on: November 03, 2015, 11:43:22 pm »
I think i have a bridged trace somewhere.  I desoldered the wires and tested one by one and got 3 of them working ( all but dpad left). Im not sure yet why the last one isn't working. I think i may have oversoldered and bridged the common ground and my one trace. Im trying to scrape back the green layer to get directly at the traces and away from the crappy solder pads which lifted.
SavannahLion
« Reply #6 on: November 04, 2015, 12:02:27 am »
You can get the schematic here: http://gamesx.com/wiki/doku.php?id=schematics:console_related_schematics
Looks like common grounds with caps for debouncing. Not sure where the M# leads go off to.
Hope those schematics and notes help.
