Author Topic: Bill Validator on Coin Door (for Mame)  (Read 4627 times)
alphasqorner
  • Last login:September 07, 2017, 10:55:43 am
  • The machine took my quarter!!!
    • AlphasQorner
« on: January 09, 2004, 12:03:57 am »
Anyone know if, for a MAME setup, a bill validator works.  Meaning, if someone were to put a dollar bill into the bill validator, (where along with 2 coin slots, there is also a dollar bill acceptor on the coin door) somehow there would be 4 credits inserted.  Not sure if I'm clear on this.
Visit www.alphasqorner.net: Home of AlphasQontroller (CP with "coin door-ed" stand)
Ken Layton
  • Guru
  • Technician
Re:Bill Validator on Coin Door (for Mame)
« Reply #1 on: January 09, 2004, 12:32:20 am »
In a JAMMA cabinet the bill acceptor's credit relay output is wired in parallel with the common and normally open contacts of coin switch 2 on the coin door. Then you configure the bill acceptor for 4 pulses per dollar (each pulse is equal to one trip of the quarter coin switch).
alphasqorner
    • AlphasQorner
« Reply #2 on: January 09, 2004, 12:39:35 am »
Cool.  Would this work on a mame cab?  How do you configure the bill acceptor?
Ken Layton
  • Guru
  • Technician
« Reply #3 on: January 09, 2004, 01:10:05 am »
Configuring a bill acceptor varies considerably from make and model. Some are configured by dip switches onboard, some are set by jumpers, some are set by a programming card. Some bill acceptors operate on 12 volts dc, while others operate on 24 volts dc, 24vac, or 120 volts AC. You may have to contact the particular bill acceptor manufacturer for specific instructions.
1Spoon
  • Last login:January 17, 2007, 03:07:47 pm
  • Cocktail projekt going on..
« Reply #4 on: January 09, 2004, 08:59:54 pm »
But you wouldn
gprime
  • Last login:November 02, 2024, 01:23:19 pm
  • still the newb
    • G-Prime .NET
« Reply #5 on: January 09, 2004, 10:35:34 pm »
I can see hooking up a coin slot to get the authentic feel of an arcade machine, but why do you want a bill validator? would you even use it?  ;D
Maybe I'm just not use to bill validators tho. Being a Canadian, it would be rediculous to have a bill validator, considering our lowest bill is a fiver  ;D
« Last Edit: January 09, 2004, 10:36:42 pm by gprime »
alphasqorner
    • AlphasQorner
« Reply #6 on: January 09, 2004, 11:47:33 pm »
