Author Topic: Illuminated pushbuttons  (Read 1489 times)
jmcginley
  • Last login:September 22, 2023, 12:23:40 pm
« on: October 04, 2015, 05:20:49 am »
For black, concave pushbuttons with RGB illuminated bezels and leaf switches, is this going to be my best option?
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=73&products_id=408
$8.95 per button just seems pretty crazy. Is there any cheaper solution that maybe I'm not aware of? Buying the button and the bezel separately from two different places maybe?
« Last Edit: October 04, 2015, 05:34:35 am by jmcginley »
big10p
  • Last login:May 01, 2023, 01:46:23 pm
  • Mmmm, arcade classics!
Re: Illuminated pushbuttons
« Reply #1 on: October 04, 2015, 05:44:36 am »
That's the price for having the optional extras of leaf switch and RGB, I guess. Also, those buttons are convex, not concave.
ChanceKJ
« Reply #2 on: October 04, 2015, 07:20:19 am »
GGG also makes a clear version of the CLASSX button that isn't shown online. you'd have to buy them plus a set of blacks to get black plungers, and then add the True-Leaf switches. quite a bit more expensive actually, but a better button.
Paradise Arcade sells a version of the IL buttons like this without the leaf. It what a couple of us have used on our cabs.
jmcginley
« Reply #3 on: October 04, 2015, 11:29:10 pm »
Did not even realize that... Good thing I didn't order!
jmcginley
« Reply #4 on: October 04, 2015, 11:38:49 pm »
Thanks for the info! I'll check out the ones at Paradise Arcade. In your opinion, are leaf switches worth the extra cost?
ChanceKJ
« Reply #5 on: October 05, 2015, 02:11:48 am »
Subjective really. I like the feel of the leaf, but there's something to be said for the click of a microswitch. Depends on a number of factors.  And if we're not careful this thread will turn into a back and forth debate over both. Haha.
Just price them out and see what you think. One over the other really won't matter in the grand scheme of things when you're building a machine that plays such a wide variety of games.
  • Last login:August 08, 2025, 09:49:26 pm
« Reply #6 on: October 05, 2015, 11:38:05 am »
Leafs are great if you're planning to play a bunch of games where you need rapid fire, like maybe Galaga or Track and Field. You're probably not going to like them for fighting games.
jmcginley
« Reply #7 on: October 05, 2015, 02:02:15 pm »
Thanks for the insight. I feel like I'd probably play fighting games more. Are they about the same with regards to durability/longevity?
jmcginley
« Reply #8 on: October 05, 2015, 02:03:39 pm »
« Last Edit: October 05, 2015, 02:06:56 pm by jmcginley »
« Reply #9 on: October 05, 2015, 02:11:50 pm »
I use the Rollies with no issue, but my first preference are the GGG leafs. Can't go wrong either way.
jmcginley
« Reply #10 on: October 05, 2015, 04:06:55 pm »
I might try the Rollies. Is there any reason why it would be a bad idea to get some stiffer microswitches for the Coin/Player buttons?
« Reply #11 on: October 05, 2015, 04:55:57 pm »
I don't see a good OR bad reason for doing so, so I wouldn't bother. I don't do coin buttons, though. Tokens all the way.
