Author Topic: Beginners question about angular edges  (Read 3968 times)
HCFREAK
  • Last login:June 06, 2017, 07:08:49 am
« on: September 23, 2015, 08:11:52 pm »
Hey guys.
I've been lurking around this site long enough, so I decided to build me own arcade machine :)
I'm currently in the process of getting all the different tools I need to work with, getting some arcade buttons and all that stuff. But there is one 'problem' that I have not yet found a really good solution to.
In the picture I made, you can see, that putting two mdf plates together in a right-angled way, obviously is not a problem (duh ^^). But what, if I wonna put them together like shown, in some kind of angular way?
Using a jigsaw, I would imagine this to be kind of awkward, or to be more specific, I wouldnt really know, how to do it. I would guess, you would have to use some kind of table, which can be adjusted in the angle you want, then somehow cut with a saw, so that it would fit.
Sorry, if this is a beginners question.... gotta start somewhere :)
  • Last login:Today at 12:08:48 am
Re: Beginners question about angular edges
« Reply #1 on: September 23, 2015, 08:20:24 pm »
Welcome aboard, HCFREAK.   ;D
Check out this thread.
  • Last login:Today at 01:22:15 am
« Reply #2 on: September 23, 2015, 08:47:05 pm »
Or just find a friend with a table saw.
HCFREAK
« Reply #3 on: September 23, 2015, 09:05:05 pm »
Thx :)
Yeah... since I dint know anyone with a table saw, looks like I'm gonna have to buy one myself.
Slippyblade
« Reply #4 on: September 23, 2015, 09:11:15 pm »
While a table saw is nice, I love me a normal circular saw with a sawboard.  Easy and inexpensive to make and WAY safer than running large panels through the
table saw.
There is a sticky on this board about them, here.
http://forum.arcadecontrols.com/index.php/topic,43568.0.html
« Reply #5 on: September 23, 2015, 09:46:15 pm »
I wouldn't buy a table saw unless you plan to use it a lot. I use mine to cut wood laminate floors, panels for chairs, and so forth. I use it for a lot more than my arcade stuff.
Slippyblade speaks wisdom if you are looking to buy tools.
GSXRMovistar
  • Last login:April 16, 2025, 06:01:17 pm
  • Gez, this is gonna be expensive!
    • forum.arcadecontrols.com/index.php/topic,148135.0.html
    • CoffeeCade
« Reply #6 on: September 24, 2015, 09:26:19 am »
If going the circular saw route consider a plunge/rail saw.
knave
  • Last login:February 01, 2025, 06:42:47 pm
« Reply #7 on: September 24, 2015, 12:01:54 pm »
Correct me if I'm wrong...but couldn't one also achieve this with a router and the right chamfer bit? (of course depending on the desired angle)
nicwald
  • Last login:December 14, 2017, 11:10:19 am
  • Lurking in your Threads.
« Reply #8 on: September 24, 2015, 01:17:02 pm »
Typically Chamfer router bits come in standard angles (45, 30, 22.5, 15). See, http://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/bt_chamf.html
That would work, but could be a costly solution depending on the number of angled cuts required as each angle would require a different bit. If you plan on making many angled cuts it could get expensive to replace bits vs buying a circular saw or a table saw
Best solutions would be a circular saw, table saw or a band saw (one of the larger versions 14"+), but a router with chamfer bits could work in a pinch for specific angles.
EvilNuff
« Reply #9 on: September 24, 2015, 04:33:00 pm »
A band saw will leave an uneven cut line, I would not recommend that.  I second the suggestion about circular saw with a guide board.  I would avoid buying a table saw as any cheap ones you get will, IMO, be extremely unsafe.
wolcott27645
  • Last login:September 26, 2015, 09:29:45 pm
« Reply #10 on: September 26, 2015, 09:07:16 pm »
If you are dead set on using MDF just remember that it may be cheaper but it does weigh quite a bit more.  I would use the chamfer bit with a zero clearance fence.  This will help keep the angle correct.  I also buy my router bits from www.routerbitworld.com.  Shipping is a $1...cant beat it!
HCFREAK
« Reply #11 on: September 27, 2015, 01:43:54 pm »
Thanks for all your replies :)
As my first project, so to speak, I am going to create a 'GameBoy Arcade', using a SNES in combination with a Super GameBoy Adapter.
Mhm, now that I think about it, maybe I should create a new thread under 'projects announcements'.
I think I'll just do that right now :)
And thx wolcott for the link, but since I live in germany, the shipping costs are of course not really an option for me. But I'm gonna get all the stuff I need here anyway.
jennifer
« Reply #12 on: September 27, 2015, 10:26:45 pm »
    I use a jointer, and will stand behind it"s precision. They are heavy dedicated, and extremely dangerous finger chewing machines however use at your own risk...My #2 choice would have to be a router table, here cheap should be frowned upon, Warped tables, and lacking above table bit changes (very time consuming)....And finally the tablesaw, a trusty workhorse that's up to the task.
