Author Topic: Dual Boot  (Read 1773 times)
DrChaos
  • Last login:January 10, 2016, 09:13:21 am
Dual Boot
« on: September 06, 2015, 12:02:27 pm »
Hi,
I am new to this forum, although I was a silent reader for a long time. Now i am doing my first steps with Groovyarcade, which I want to use in my Naomi. I installed GA on an additional harddrive, but I would like to have a dual boot option. Is there an easy way to install a bootmanager?
thanks...
RobeeJ
  • Last login:August 20, 2025, 03:36:59 am
Re: Dual Boot
« Reply #1 on: September 11, 2015, 03:50:02 am »
Is Naomi the Dreamcast arcade board?
GroovyArcade would have installed a bootloader already, so it would just need configuring for whatever original OS you need to launch.
DrChaos
Re: Dual Boot
« Reply #2 on: September 13, 2015, 05:53:11 pm »
Well, in other boards 'Naomi' is often used for the 'Naomi Universal cab', but that was often equppied with the Noami Arcade Board, which is similar to a Dreamcast. In my Case there is a Noami 1, so the answer is Yes ;)
Regarding the Bootloader - from my old days in Linux I now remember that the cahnges could be made by a textfile. Can someone point me to a documentation which works for GroovArcade?
Thanks a lot!
RobeeJ
Re: Dual Boot
« Reply #3 on: September 14, 2015, 03:40:37 am »
I'm not sure for certain, but you'd be able to tell pretty quickly, I think it uses syslinux:
https://wiki.archlinux.org/index.php/Syslinux
DrChaos
Re: Dual Boot
« Reply #4 on: September 14, 2015, 06:26:25 pm »
Thanks, I will check that out.
