Author Topic: Is there a Template that maps out what each of 8 buttons should do?  (Read 3192 times)
j1345
  • Last login:April 12, 2020, 03:38:08 am
I'm in the process of finishing up my first vigolix MAME cabinet build and I installed 8 buttons plus joystick but have no idea what the best way to organize these buttons to do what function.  Does anyone have a finished map of what they programed each of the 8 buttons to do?
Thanks in advance.
Re: Is there a Template that maps out what each of 8 buttons should do?
« Reply #1 on: August 28, 2015, 12:04:49 am »
Button 1 - Low Punch
Button 2 - Medium Punch
Button 3 - High Punch
Button 4 - Low Kick
Button 5 - Medium Kick
Button 6 - High Kick
Button 7 - Sit The ---fudgesicle--- Down
Button 8 - Shut The ---fudgesicle--- Up
Hope this helps.
« Reply #2 on: August 28, 2015, 12:10:07 am »
Button 4 - Low Kick
Hope this helps.
Hmmmm.... I need a run button. Got any 9 button templates?
matsadona
« Reply #3 on: August 28, 2015, 02:32:26 am »
Hm... If you don't know the purpose of the buttons, do you really need them?  ???
The first question to be asked is what kind of games you will play. With that answer you should know what buttons you need.
Most of the classic games generally use only two or three buttons, with some obvious exceptions like Defender (but for that game you can map some buttons to the joystick).
If you are in to NEO GEO games you will need 4 buttons and most of the 90's fighters (Street fighter & Killer instinct) uses 6 buttons.
There are many examples here with a seven button layout so you get the 4 NEO GEO buttons and the 6 button fighter layout combined.
Having more buttons is usually because of emulating newer console games, but me personally thinks that the controllers with shoulder buttons etc doesn't translate well in to an arcade control layout. Of course this is a matter of personal taste.
  • Last login:Yesterday at 12:04:48 pm
« Reply #4 on: August 28, 2015, 08:53:14 am »
In MAME, map them globally like so:
1237
4568
By default MAME assumes you have a 6 button layout like this:
123
456
so if you keep those core 6 like that, the majority of games will already be mapped correctly.
Here are the default MAME keyboard keys if that's what you're after:
If possible with your encoder, I recommend changing the first four to standard letter keys.
It will save you trouble down the road when you add other emulators that can't use those keys.
(I haven't run into any issues with the bracket keys on P2)
Also prevents windows hotkey combos from accidentally being triggered.
« Last Edit: August 28, 2015, 09:10:53 am by BadMouth »
« Reply #5 on: August 28, 2015, 08:56:26 am »
are 2 of the buttons coin and start?
burn_654
  • Last login:April 29, 2025, 04:25:44 pm
« Reply #6 on: August 28, 2015, 01:34:12 pm »
Personally, on my jpac 6-button setup I wired mine like this:
456
123
And went through my six-button games in Mame and setup the keys specifically. This is a little different than some setups.
My methodology was that:
1. I found I much preferred the bottom three buttons for games that used 3 or less.
2. In this way, all three button games were already set up control-wise in mame for the bottom 1-2-3 buttons without having to touch anything.
3. It was easier long-term to set up controls for the ~15 fighting games I have so far than the sheer number of three button games I have or will eventually have.
Hope you find this useful!
Also, for the love of god disable sticky keys. I don't see that mentioned a lot but the first time someone mashes your 'shift' key you'll be seeing it.
« Last Edit: August 28, 2015, 01:38:50 pm by burn_654 »
« Reply #7 on: August 28, 2015, 02:30:52 pm »
456
123
Great feedback!
eds1275
  • Rock and Roll!
« Reply #8 on: September 02, 2015, 11:31:24 am »
I'm crazy. I went like this:
   5 1 6
   2 3 4
1
that way for 6 player games I have the inputs, and a run for MK3. 4 along the bottom for neo geo or anything else with up to 4 buttons, and I don't waste an input. Also those that are more comfortable with MK running using a street fighter layout are also happy.
