Author Topic: Zero Delay Encoder - Noob question  (Read 4163 times)
flavad99
  • Last login:September 06, 2016, 08:34:00 pm
« on: August 22, 2015, 06:14:44 pm »
I believe I lost the instructions to the encoder or didn't receive them.
It has always been my understanding that I would need to daisy chain a ground wire each of the buttons, however in the package I received, it looks like I got nothing but wires that split two ways at the connection point to the encoder.  Do I simply connect both of these wires to the Happ Button, which has three connecting points.  Is there basically just a ground wire between every button and the encoder?
Again, sorry for the noob question.
05SRT4
  • Check out my Pow Pow
Re: Zero Delay Encoder - Noob question
« Reply #1 on: August 22, 2015, 06:21:50 pm »
After doing a quick google search I was able to find This Picture
If those wires/connectors look the same then you should be able to connect the 2 ends to the button / joystick switch and then just plug it in.
Hope this helps.
Slippyblade
« Reply #2 on: August 22, 2015, 06:23:43 pm »
First off, in regards to microswitches that have 3 contacts, it is important to pay attention.  One of the connections is ground, one contact is a normally open switch, the other contact is a normally closed switch.  After you wire it up if it seems like the button is stuck in a pressed state - switch the connection.
Secondly, yeah, you are correct.  Each switch just has it's own ground connection in that situation.
flavad99
« Reply #3 on: August 22, 2015, 06:25:49 pm »
Awesome, thanks guys
