Author Topic: Printing marquee?  (Read 1342 times)
megamoze
  • Last login:December 18, 2024, 04:05:59 pm
  • Loving my cabinet, built summer 2015
Printing marquee?
« on: August 17, 2015, 07:44:53 pm »
I did a search on the site on the only result I could find was a guy whose page redirects to the Hyperspin main page.
What material do you recommend and who do you use?  Mine will be sandwiched between two layers of plexiglass (also, what is the recommend thickness of the plexiglass?).
cadillacman
  • Last login:November 07, 2023, 01:06:58 pm
Re: Printing marquee?
« Reply #1 on: August 18, 2015, 01:07:04 pm »
WHEN I PUT TOGETHER MY MAX FORCE/AREA 51/AREA 51 SITE 4 TRIO I HAD RICH AT THIS OLD GAME PRINT IT OFF FOR ME ON SOME KIND OF PLASTIC.. SAME TYPE AS A OE TRANSLITE.  CAME OUT PERFECT AND HE WAS REASONABLE TOO.
JDFan
« Reply #2 on: August 18, 2015, 01:43:46 pm »
There is a thread in the BST sub-forum for $15 marquee printing on translite material that is designed to be backlit. which is a good deal and good material for what you are wanting (ie. it is a thinner material so sandwiching between plexi is a good way to use it !) Plus since he is a member here you will not run into problems with certain places not wanting to print copyrighted images if using some old original arcade art :cheers:
See here - ( http://forum.arcadecontrols.com/index.php/topic,143964.0.html )
« Last Edit: August 18, 2015, 01:45:17 pm by JDFan »
vwalbridge
« Reply #3 on: August 18, 2015, 02:13:34 pm »
Yep, BYOC member stpcore does awesome prints. Here is my translite marquee I ordered just a couple weeks ago. I wish the "blacks" were darker but this is the nature of translite. I might be able to do another "shadow" print behind this one that blocks out more light but only in the black areas.
  • Last login:July 11, 2025, 09:17:44 am
« Reply #4 on: August 18, 2015, 04:19:33 pm »
GameonGrafix.com
You can order it with or without the plexi for the front and back.
D
megamoze
« Reply #5 on: August 18, 2015, 04:28:11 pm »
Thanks!  Sent him a PM.
megamoze
« Reply #6 on: August 18, 2015, 04:28:54 pm »
GameonGrafix.com
D
I checked them out.  I like their work and their prices.  I didn't see them also selling plexi for front and back.  Thanks!
« Reply #7 on: August 18, 2015, 06:08:52 pm »
The plexi option is the drop down.  I also used the ultra premium material for the marquee.
