Author Topic: TV power button replace.  (Read 1055 times)
kiel0909
  • Last login:May 23, 2022, 02:59:10 pm
« on: August 06, 2015, 01:10:48 pm »
I took the casing off the Monitor Ill be using today, I need to move this power button so that it is accessible from the outside of the cab, obviously i want to use an attractive button.  Ive never done anything like this before.  I need to de-solder the button, solder in wires and then connect those wires to a new button.
1. what gage wire do i use? does it matter as long as it fits in the PCB?
2. what should i search for to find an appropriate button, it has 4 contacts, does it have a certain name? any suggestions?
Re: TV power button replace.
« Reply #1 on: August 06, 2015, 01:50:50 pm »
take a small piece of wire with both ends stripped a little.
touch it to 2 points of the 4 at a time. When the TV turns on, those are the 2 points you need to solder to your new button. You don't need to remove the old button, just solder your leads to the bottom of the board.
kiel0909
« Reply #2 on: August 06, 2015, 02:11:49 pm »
excellent! i found the 2 contacts! can i use an arcade button and micro switch to activate it?
JDFan
« Reply #3 on: August 06, 2015, 02:14:09 pm »
Yep - any momentary switch will work just wire it like you would a normal button using the NO and Gnd connections on the microswitch.
« Reply #4 on: August 06, 2015, 03:24:25 pm »
^ This.
And since you aren't wiring anything else in line with the button it doesn't matter which wire goes where. Just run 1 lead to the ground prong and the other to the NO (Normally Open) prong.
