Author Topic: Question about Ultimates from HAPP  (Read 1030 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: January 02, 2004, 11:02:52 am »
How big does the hole on my control panel artwork need to be for the Ultimates stick to move without messing with my artwork?
OSCAR
    • Oscar Controls
Re:Question about Ultimates from HAPP
« Reply #1 on: January 02, 2004, 11:39:10 am »
A 1-1/8" hole will work, but make sure you have it centered if you are using a 3/4" wood control panel.
If you will be installing the dust cover on top of a wood control panel, figure that the 2" dust cover will take up approx the same area as a 2-5/8" diameter circle when the joystick moves full travel in all directions, if that is a concern for your artwork.
chrisindfw
  • I drank what?
« Reply #2 on: January 02, 2004, 11:42:25 am »
Pardon my stupidity. What exactly is the dust cover?
OSCAR
    • Oscar Controls
« Reply #3 on: January 02, 2004, 11:46:30 am »
The large 2" diameter plastic washer that is sometimes installed on top of the control panel (most wood control games), or underneath the control panel (if metal cp).
chrisindfw
  • I drank what?
« Reply #4 on: January 02, 2004, 11:47:35 am »
Thanks! Thought that was what it was called.
2slk
  • Last login:February 27, 2004, 11:38:09 pm
  • Fascinating, Captain.
« Reply #5 on: January 04, 2004, 01:17:46 am »
My advice would be to worry less about the holes for now and worry more about exchanging the ultimates for comps or returning them and buying J-sticks or T-Sticks. Just my opinion. Don't want to start another joystick war here.
