Author Topic: Return of the Cab Work: hardware update?  (Read 897 times)
Chris2
  • Last login:September 28, 2024, 09:56:40 pm
  • Servin' up Bacon.
« on: June 26, 2015, 04:30:41 pm »
Hey all, I decided the other day that it was time to go back and finally finish my cab project from years ago. The one thing I decided to change was to make it a mobile pedestal setup which could plug into many different displays. That said, what are some good video card(s) to consider for connecting to composite/s-video/component/HDMI/VGA/DVI/DisplayPort? Most important would be composite, VGA, and HDMI, but the more the merrier I say. Current card I have in my mamebox is a http://www.newegg.com/Product/Product.aspx?Item=N82E16814145146 which is obviously pretty out of date now.
I might be up for considering a whole new build if need be, so don't feel afraid to recommend some cards that may not work in my mobo (http://www.newegg.com/Product/Product.aspx?Item=N82E16813138098), and as always thanks for reading.
"Do you like Huey Lewis and the News?"
haynor666
  • Last login:November 21, 2025, 05:45:00 pm
  • retro maniac
Re: Return of the Cab Work: hardware update?
« Reply #1 on: June 26, 2015, 05:39:21 pm »
Composite and s-video are almost obsolete, at least in EU. Most of the modern cards have now 2 DVIs (one usually only digital and one with analog output) and HDMI. Some have also display port. Are you planning to use some opengl shaders ? If not and you are using it only for mame probably you don't need to replace it. I'll rather inwest in new board and processor.
