Author Topic: i-Pac delay?  (Read 1222 times)
gprime
  • Last login:November 02, 2024, 01:23:19 pm
  • still the newb
    • G-Prime .NET
i-Pac delay?
« on: January 01, 2004, 12:07:55 am »
Just got my i-Pac yesterday, hooked it up today. All the buttons work 100% except I noticed 1-player start doesn't work until you release the button (for every other button, it works when pressing it down). Not sure if you understand what I mean. Is this normal? No biggy; just curious.
Generic Eric
Re:i-Pac delay?
« Reply #1 on: January 01, 2004, 02:56:23 am »
Can't help you directly, as I don't have an I-Pac.  I do know that Andy Warne is very helpful when it comes to his products.  Shoot him an email and ask him.
Happy New Year!
JustMichael
  • Mmmmm!! Cheesecake!!
Re:i-Pac delay?
« Reply #2 on: January 01, 2004, 03:12:03 am »
This is normal.
slicer_d
  • Last login:November 06, 2013, 12:51:11 am
  • Yay n' stuff
Re:i-Pac delay?
« Reply #3 on: January 01, 2004, 03:32:22 am »
I think its because it also acts as a shift button.  So when it is pressed down it waits to see if you are going to press anything else first then if you dont it just does what its supposed to do ala start player 1.  I bet you can turn it but I cant say for 100% sure.
gprime
  • still the newb
    • G-Prime .NET
Re:i-Pac delay?
« Reply #4 on: January 01, 2004, 04:00:10 am »
Ah thanks! I was just thrown off because player-2 start didn't act the same.
Re:i-Pac delay?
« Reply #5 on: January 01, 2004, 11:53:37 am »
I didn't realise that, I suppose you could reprogram 'shift' to a different key if it bothers you...
NoOne=NBA=
Re:i-Pac delay?
« Reply #6 on: January 01, 2004, 01:39:32 pm »
I would actually RECOMMEND that you reprogram it to avoid the possibility of someone hitting both player starts at the same time.
During that combination, the P-1 Start sends a "Shift" signal, and the P-2 Start sends an "Exit" command.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re:i-Pac delay?
« Reply #7 on: January 02, 2004, 05:03:41 am »
Yes, whichever key is the shift key, waits until being released before sending the code. This is because it needs to know whether any other key has been pressed in the meantime, ie whether you are using it as shift, or it's normal function.
You don't have to have a shift key at all if you don't want to, you can unassign it completely.
