Author Topic: UltraStick, IPac and Xpadder  (Read 3014 times)
tonycrew
  • Last login:June 27, 2015, 11:05:27 am
« on: June 19, 2015, 07:24:05 pm »
Ok having a nightmare with this just installed 2 new Ultra360's and IPac 2, all detected fine in windows, Using hyperlaunchhq all ipac button presses show correctly.
Ipac Firmware is 1.30 , Windows 7 64 Bit, Radeon R9 270 GC, AMD 8320E CPU.
Now in Xpadder i see 3 icons at the top IPAC2 - UltraStick 1 - Ultrastick 2
But when i Select IPac then create a new Layout no button presses appear on edit screen
And how do i link the UltraStick and Ipac button presses together in hyperlaunchHQ, Do i create 2 profiles in the bottom window of the keymapper in HLHQ..?
tonycrew
Re: UltraStick, IPac and Xpadder
« Reply #1 on: June 19, 2015, 09:34:22 pm »
Ok i got them working in hyperspin, i then set up profile for epsxe but when i launch a game xpadder closes..?
EMDB
  • Project RetroCade
« Reply #2 on: June 20, 2015, 07:37:48 am »
If you want your Ultrasticks to behave like a digital joysticks(e.g. firing key strokes for both the directions and the buttons) you should just connect them to the ipac using the 10 pin I/O harness instead of using xpadder.
tonycrew
« Reply #3 on: June 20, 2015, 10:50:19 am »
Thanks for the info, at the moment when i select a profile HLHQ isnt selecting/changing profiles..?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #4 on: June 22, 2015, 09:26:49 am »
That would work but you lose the abilty to apply maps to the sticks. Mame is quite happy with game controller buttons and axes.
We have received many support emails from people using Xpadder, some of which have taken a while to resolve owing to the strange nature of the problems. After removing Xpadder all the issues have gone away.
EMDB
  • Project RetroCade
« Reply #5 on: June 23, 2015, 12:10:03 pm »
You should leave the USB cable connected too. This way you can both download maps AND still have the stick trigger keyboard presses using the iPAC being more flexible in controlling emulators and front ends.
