Author Topic: Cabinet Controls Height?  (Read 829 times)
bsoder52
  • Last login:June 24, 2025, 11:29:40 pm
« on: June 09, 2015, 04:10:57 pm »
So I'm building my 2nd cab ever, and this one is going to be a control panel (Xarcade Tank Stick) mounted on half cab with a wall mounted flatscreen.  (Kind like a golden tee set-up).
Just not sure how tall to build the base the Tank Stick will sit on.  Hopeful there is a standard out there for how all the control panel surface should be off the ground?
Thanks in advance for any help!
Bsoder52
  • Last login:August 19, 2025, 03:10:32 pm
