Author Topic: Control issues  (Read 1301 times)
Buick455
  • Last login:April 03, 2024, 03:24:29 pm
  • I MUSTA WRECKED IT!
Control issues
« on: April 07, 2015, 03:25:41 pm »
I'm having some control issues  :banghead:
I have installed a ServoStic, 2 action buttons, 2 player start buttons & 2 Coin. They are connected to the PC with a Kade encoder. For the most part everything seems to be working fine except while playing "vs Super Mario Bros" I get what feels like key blocking which (afaik) shouldn't happen with the Kade.
I will try an explain whats going on.. I am moving (right), holding (fast/fire) and when I go (left) then (right) again mario sometimes becomes stuck until I let go and start over.
When I force the ServoStic into 4-way mode it plays fine.. Everything I find online states it was a 8-way but I don't remember the game playing like this with my old iPac/Happ 8-way panel. I cant figure out if its the stick, the kade or the idiot mashing the buttons  :dizzy:
« Last Edit: April 07, 2015, 03:56:11 pm by Buick455 »
TapeWormInYourGut
  • Last login:January 24, 2026, 09:43:12 am
Re: Control issues
« Reply #1 on: April 07, 2015, 06:27:19 pm »
I don't have an IPAC or ade, but I would be a little surprised if the I-PAC didn't have the same issue. As soon as you hit a diagonal, the character will stop moving and is common for some 4-way games. When you switch to 4-way, it eliminates the problem by simply making it impossible to hit a diagonal direction. It is essentially a problem with the game because it wasn't coded to handle diagonal inputs.
So I can't really help you, I can only confirm that what you are experiencing is normal behavior. I doubt that it is a problem with your encoder.
DarthMarino
  • Last login:December 17, 2025, 10:53:45 am
Re: Control issues
« Reply #2 on: April 07, 2015, 07:20:22 pm »
I just tried the game out on a keyboard. If you are holding down, Mario will not walk at all.
mgb
  • North East, US
Re: Control issues
« Reply #3 on: April 08, 2015, 08:06:01 am »
it sounds like the square restrictor is giving you the issue. I'm sure its not a problem with the kade.
so many modern sticks have square gates and of course sticks like the servo stick rely on them in order to switch between 4 and 8 way. Problem is, IMO the square gate sucks for 8 way and makes it very easy to slip into the diagonal.
I'd bet that if you tried your exact setup but change the stick to a simple cheap happ super, you'd have no problem.
Buick455
Re: Control issues
« Reply #4 on: April 08, 2015, 08:34:20 am »
Thanks guys, I was going nuts trying to pinpoint the issue, I think MGB got it..
I played for 10min in 8-way and it does seem like I'm doing what MGB & Darth said. Not LEFT and DOWN (I would notice mario crouching) but LEFT and UP you cant see.
Does anyone see a problem with running it in 4-way?
If not, I think I will solve the problem by editing the controls.ini to use 4-way instead of 8-way for this game.. I know whats happening now and can compensate, where as visitors wont..
mgb
  • North East, US
Re: Control issues
« Reply #5 on: April 08, 2015, 07:45:48 pm »
I would think super Mario would be fine with 4 way
