Author Topic: Dreamcast emulator question  (Read 1954 times)
Generic Eric
« on: March 30, 2015, 10:48:57 am »
I thought there was a DC emulator thar played real discs?  Is that true?  Or am I wrong?
eds1275
  • Last login:October 06, 2025, 04:35:27 pm
  • Rock and Roll!
Re: Dreamcast emulator question
« Reply #1 on: March 30, 2015, 02:25:36 pm »
I think you can do that in NullDC?
Generic Eric
« Reply #2 on: March 30, 2015, 02:49:48 pm »
Thanks.  I wasn't sure if I was imagining that or if that was a feature that may or may not have been dropped.
I also seem to remember that you could mount the iso with alcohol 120% and have it play too.  I could never get anywhere with the emus though.
nitrogen_widget
  • Last login:September 12, 2025, 07:07:08 pm
« Reply #3 on: March 31, 2015, 01:25:18 pm »
From what I used to know, the dreamcast used GD-ROM?
a non-standard disc size but you could back-up the discs to CD-rom using your dreamcast & a serial cable connected to the PC and one of the emulators made the connection.
Then you could burn it to CD & play it on the dreamcast.
If it took up the whole dreamcast disc you had to use a boot disc to run the game first because those files had to be moved off in order to fit the game.
butanebob
  • Last login:June 03, 2022, 05:29:52 am
« Reply #4 on: March 31, 2015, 07:11:03 pm »
Yep, i don't think any emulator can run original DC discs.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #5 on: April 01, 2015, 04:19:03 pm »
Normal PC disc drives can't read original Dreamcast discs because they're in the proprietary GD-ROM format.... I think there was someone who found certain model drives that can be modified (both hardware and firmware) to read them for ripping purposes but that seems like a lot of work for emulation.
Any Emulator that is able to run mounted ISOs should be able to read backup discs directly from the drive though.
Generic Eric
« Reply #6 on: April 01, 2015, 04:42:20 pm »
This is most likely what I was thinking.  I definitely remember updating firmware being a thing.
jdevane
  • Last login:September 29, 2023, 09:27:07 pm
« Reply #7 on: April 05, 2015, 10:00:46 am »
LG made that drive, I have one, however, I have it installed in an external enclosure so unless I need to tear it all apart, I can't get the model number...  its the same drive the Wii disc need to be read...
« Last Edit: April 05, 2015, 10:03:56 am by jdevane »
