Author Topic: CP Locking  (Read 2314 times)
Taflad
  • Last login:September 06, 2016, 01:43:40 pm
CP Locking
« on: March 29, 2015, 07:10:11 am »
Good morning all,
I am after some advice for my cab. Before I start a build, I want all details ironed out. I understand that most control panels are in a box and lock in, then can be hinged to access the wiring etc. I plan on building just a flat piece of mdf (18mm) and fixing it to the sides with some sort of latch. I do this as the pc used to run the system is pretty powerfull, and I will be using it for PC games. For this, I have designed a keyboard drawer directlu inder he cp. I was wondering what sort of latch would be suitable for attaching it to keep it sturdy when latched. I have added a picture to help, as I may not be explaining myself very well.
Many thanks
lamprey
Re: CP Locking
« Reply #1 on: March 31, 2015, 01:01:00 pm »
I generally use a control panel latch. I'm not 100% sure if I follow you about how you want to mount the CP, so that may not work for you. However, it'll certainly hold it tight! :)
  • Last login:June 25, 2025, 03:09:16 pm
Re: CP Locking
« Reply #2 on: March 31, 2015, 02:35:59 pm »
+1 on the CP latch. Having just a flat board for a panel is common in commercial cabs, and latches are used there as well.
Am I to understand that you will have the underneath of the controls exposed? Or are you planning on a front that isn't shown in that render?
Taflad
Re: CP Locking
« Reply #3 on: April 01, 2015, 01:47:39 pm »
Hi both, thanks for the replies and sorry for my late reply. Yes, I will have a hinged board where the gap is now to hide a keyboard/mouse drawer. It not in the image so I can show the area I mean
