I have a wall mounted NSM fire country, we recently moved home so I stripped it down to make it easier to lift, it worked fine when i first connected but now the cd will not lift, motor tries to turn and then an error 75 comes up which is not in my manual. the lift works ok with the power off by moving belts but then locks when i power on, i wonder if someone could help
