February 07, 2026, 10:37:55 pm
You can probably fix that. Do you have a soldering iron?
Anyone try recalbox? http://www.recalbox.com
Run at all or run without pulling out your hair? To be honest, I never tried turning off all effects in Hyperspin. And I guess at that point, what is the point vs another FE
Probably at all, since it's so Flash-based. Anything less than a Core2Duo and Hyperspin = GTFO. And even at that, you need to turn stuff off.I'd be happy with something simple and configurable.
Nice. Let us know what you do with it. Mine is coming in today(hopefully). Will probably try Plex on it first then emulation station again.
hdmi to vga requires a converter from digital to analog and they usually run about 30 bucks.
I am going to try running final burn alpha. Haven't loaded anything to microsd yet. Here's where I'm at with the console project. Awaiting a few parts in the mail before purchasing an enclosure.
hdmi to vga requires a converter from digital to analog and they usually run about 30 bucks, now if you have a dvi monitor a hdmi to dvi stays digital and you can get them on ebay for about 5-7 bucks.
Still testing it, but yeah, you do see Linux loading screens, especially after quiting.I don't have Stepmania, but it can run Quake III Arena, so I would think so.
I've got a recommended 5v 2A charger powering the Pi2. What does the USB port output in terms of Amps?
Quote from: Wired203 on February 21, 2015, 11:30:51 pmhdmi to vga requires a converter from digital to analog and they usually run about 30 bucks, now if you have a dvi monitor a hdmi to dvi stays digital and you can get them on ebay for about 5-7 bucks.IF you don't mind waiting for a few weeks for it to arrive you can get them on EBAY from China for about $7 -- I just received one of these the other week for the GameStick I had bought on clearance and it works fine for connecting the GameStick to my Acer Monitor and also has the audio output for a cheap set of Logitech speakers. ( I originally got a $5 HDMI to DVI convertor but that lacked the audio and the gamestick didn't have separate audio outputs and doesn't support the $1 USB Soundcard from China either ! ) - Linkie to the one I purchased - ( http://www.ebay.com/itm/221588431594?_trksid=p2059210.m2749.l2649&var=520447402104&ssPageName=STRK%3AMEBIDX%3AIT )
Tested them both today. EmulationStation is still better looking than PiPlay.
Quote from: yotsuya on February 24, 2015, 06:46:26 pmTested them both today. EmulationStation is still better looking than PiPlay.The burning question for me is how well will it play some of the classics such as tempest and defender......
Quote from: Admiral688 on February 24, 2015, 08:00:59 pmQuote from: yotsuya on February 24, 2015, 06:46:26 pmTested them both today. EmulationStation is still better looking than PiPlay.The burning question for me is how well will it play some of the classics such as tempest and defender......Probably the same, since they both use the same versions of Mame4All/AdvanceMAME and romsets.
Case arrived. Panel mount cables are a little too bulky and inflexible. I need to put some thought in this. Is it safe to remove the sheath/shielding on these cables?
Quote from: keilmillerjr on February 25, 2015, 04:38:26 pmCase arrived. Panel mount cables are a little too bulky and inflexible. I need to put some thought in this. Is it safe to remove the sheath/shielding on these cables?I wouldn't unless you plan on cutting the down to size and repacking. Have you checked out smaller cable like the ones from adafruit?https://www.adafruit.com/category/33
Quote from: otsep on February 25, 2015, 11:37:20 pmI wouldn't unless you plan on cutting the down to size and repacking. Have you checked out smaller cable like the ones from adafruit?https://www.adafruit.com/category/33That's where I got them from.
