Author Topic: Coin doors and mechanisms  (Read 2160 times)
Blueic5
  • Last login:December 16, 2018, 05:31:20 pm
« on: January 10, 2015, 03:55:27 pm »
Just looking at coin doors and mechanisms the one in think for instance,  however I can't see where the microswitch is on the pictures,  is it just a given that's it's on there?
http://www.arcadeworlduk.com/products/calle-3-5-inch-mechanical-coin-mechanism.html
« Last Edit: January 10, 2015, 05:14:21 pm by Blueic5 »
ed12
Re: Coin door mechanism
« Reply #1 on: January 10, 2015, 04:13:39 pm »
that is because u are looking at the actual coin mech..the micro s/w
is normaly part of the coin mech holder >on-door<,not the coin mech
ed
mgb
  • North East, US
« Reply #2 on: January 10, 2015, 04:42:44 pm »
Yeah, the switch goes below the coin mech.
The coin mech only determines if the coin is allowed and then if so, its let's the coin through to the switch.
Blueic5
« Reply #3 on: January 10, 2015, 05:13:47 pm »
http://www.arcadeworlduk.com/products/Mini-Coin-Door.html
On the second pic then it looks like the metal bit at the top?   Also do these coin doors all have the ability it light up the reject button?
mgb
  • North East, US
Re: Coin doors and mechanisms
« Reply #4 on: January 10, 2015, 06:13:02 pm »
On the 2nd pic from your link, its the coind door without a switch or mech.
The metal tab at the top rear is for holding in the coin mech and the switch would get installed underneath the mech.
There is also a bulb on there behindthe reject button. You would typically hit that with 6 volts to light the reject.
stavros693000
  • Last login:December 14, 2022, 05:33:15 pm
  • I built my own arcade machine
« Reply #5 on: January 11, 2015, 01:14:19 am »
Apex Elite Upright Arcade Machine £3,995  :o  thats like $7,500 Australian WTF
unless im missing something here, i mean it does come with a 20" monitor >:D
my first build classic style upright cabinet..... MARVELOUS FIGHTER (FINISHED) http://forum.arcadecontrols.com/index.php/topic,133066.0.html
Blueic5
« Reply #6 on: January 11, 2015, 03:28:50 am »
Right that's pretty useless to me then :( I think I'll look at the happ UK catalogue thanks.
Blueic5
« Reply #7 on: January 11, 2015, 03:32:51 am »
I'm thinking you may have posted in the wrong thread..   I've not been able to find anything over 19"" lcd unless that's a crt  in the pic.
Blueic5
« Reply #8 on: January 11, 2015, 07:35:23 am »
Hmm,  this coin door stuff is complicated...   All I wanted was a double entry over under mini coin door and all the bits I need to get it working.   Happ catalogue is confusing also as to what parts I need to order :(
keilmillerjr
  • Web Developer.
« Reply #9 on: January 11, 2015, 07:54:18 am »
I think you want this.?
Over/Under Door with Cashbox and Full Metal Enclosure
Part # 40-0038-00
http://na.suzohapp.com/amusement_products/coin_doors/40-0038-00
Ask if they will swap with a uk mech?
Blueic5
« Reply #10 on: January 11, 2015, 08:10:53 am »
Perfect that seems to come with everything I need,  I'll try and fine in UK catalogue now
