Author Topic: WinIPAC for IPAC4  (Read 1395 times)
wivelden
  • Last login:January 04, 2015, 06:46:57 am
WinIPAC for IPAC4
« on: December 29, 2014, 01:59:52 pm »
Im trying to set up two buttons that will exit when they are both pressed together. I know one has to be a ---steaming pile of meadow muffin--- key. The buttons currently are a Pause and an Enter. Is it possible to set it up so that when they are both pressed it will exit?
  • Last login:Today at 03:53:59 am
Re: WinIPAC for IPAC4
« Reply #1 on: December 29, 2014, 02:33:01 pm »
The easiest way is to use "shifted" functions.
P1 Start is the default shift key, but you can change that if you want via the WinIPac software.
wivelden
« Reply #2 on: December 30, 2014, 06:13:20 am »
I set the shift key up as shown but why is it when I press the shift key and the other key it wont escape. Looking at the picture what have I done wrong?
« Reply #3 on: December 30, 2014, 01:18:56 pm »
Just to confirm, you did click on "program" and got a message confirming that the board was programmed successfully, right?
wivelden
« Reply #4 on: December 30, 2014, 01:50:53 pm »
Haha  Yes I did.  :D
Brian74
  • Last login:April 21, 2025, 11:11:53 am
  • Yep... I built that!!
« Reply #5 on: December 30, 2014, 04:03:46 pm »
I was trying to do this yesterday on my j-pac. I had to run the program as admin to get it to save.  :cheers:
wivelden
« Reply #6 on: December 30, 2014, 04:56:32 pm »
I always run as admin. I'm on Windows 7 x64. I can set the shift key to p3sw7 which is currently set as Pause (p) and I have set the shift button to be escape under sp3sw8. When I press p3s8 which is set as Enter it doesn't shift to escape as set. I press and hold and it just doesn't work at all. I have checked both wirings on the buttons and they are both set as NO. I've checked the connection to the ipac4 too and its all correct. I just don't know why it wont work.
wivelden
« Reply #7 on: December 31, 2014, 06:47:54 am »
Well for some reason you can only set Player 1 Start button as a shift key. I have no idea why you cannot set two or any other keys. Its Player 1 Start and nothing else. The software is misleading as it shows you can change it and have two. Why is it like this? :( :(
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: January 01, 2015, 12:12:29 am »
You can change the shift key to any key but you can only have one shift key on pre-2015 boards.
I can check your IPC (config) file if you can send it, but I wont be able to check it until after 9th.
Andy
