Author Topic: Multiple wires on Jamma edge connector overloads and transmission problems?  (Read 2458 times)
vanwatson
  • Last login:January 02, 2015, 09:21:39 pm
For Edge connectors and Jamma Edge connectors it says in arcade manuals not to put multiple wires on the same edge connector trace because it will cause overloading and transmission problems
Why does it cause overloading problems? and transmission problems?
The +5 volts and +12 volts wires are not to be soldered to the same edge connector trace because it causes overloading and causes transmission problems
ed12
exactley what fregen manual are u reading ?
ed
vanwatson
it's for all the arcade manuals in the 80's, it says not to put multiple wires on the same or going to one edge connector leg trace it will it cause overloaded and it will cause it to burn the jamma board trace
ed12
news flash
jamma dose exactley that...
all wire's are routed to a single dual side connecter
ed
lilshawn
  • Last login:Yesterday at 03:38:02 pm
...so don't do it.
or do...and burn up your "connector leg traces"
IE: the connector can only take so much current before burning out. the connection is only made for low current draw. drawing excess current will burn out the connector. using the JAMMA harness AS DESIGNED won't cause issues.
vanwatson
So it's the connectors copper traces, the edge connector
The Copper traces on the edge connector can only handle low current draw?
  • Last login:Yesterday at 05:49:10 pm
why do you guys bother answering? if you stop, maybe it will quit posting.
  • Last login:Today at 05:29:45 am
:stupid   :troll:
SavannahLion
Someone answered but it wasn't quite right as to dips question. Makes sense to clarify in case some other dip comes along and thinks it's the right answer.
Nonetheless, I'll remind clueless to make better use of Google, yet again.
