Author Topic: A "Tully"-copy - Current status: Credit button question  (Read 44290 times)
johnrt
Re: JAMMA Multicab - A Cabaret based on LT's Asteroids Deluxe?
« Reply #40 on: February 12, 2015, 03:35:41 pm »
So today I finally managed to cut many of the back, front and bottom panels. I'm using 15mm plywood. The woodshop has a saw for cutting the plywood sheets (see pic). So I got them to cut the sheet in three parts, 2 parts in 42cm width and the last part then turned out 38 cm. It's very precisely cut. So then my "Tully"'s inner width is 42 cm, the 38 cm spare one is for my Pole Position bartop. Nice planned! :-)
Enough rubbish, here's the pics:
« Last Edit: February 12, 2015, 03:37:55 pm by johnrt »
johnrt
Re: JAMMA Multicab - A "Tully"-copy - Current status: it's upright!
« Reply #41 on: February 13, 2015, 01:31:24 pm »
Today I mounted the wheels and a handle. I'm sorry if I'm being too detailed about this project. I'm a slow builder.
This is the most accurate cab I've ever built. It's the fifth cab I'm building and I'm just starting to get the hang of it.
Here's todays pics:
« Last Edit: February 13, 2015, 05:17:23 pm by johnrt »
BorgDog
« Reply #42 on: February 13, 2015, 02:39:31 pm »
Looks nice and clean.  Jealous of the panel saw   :cheers:
And speaking of "the" Tully, where did all his posts go?
My Projects:
johnrt
« Reply #43 on: February 13, 2015, 02:42:12 pm »
I'm not using a saw. I'm only using the router with a copy-bit. I love my router by now.  :lol
BorgDog
« Reply #44 on: February 13, 2015, 02:49:33 pm »
This saw!  And I love my routers as well.
My Projects:
« Reply #45 on: February 13, 2015, 02:55:18 pm »
Source on that handle?  Need something similar for my JAMMA Access Panel.  Good job by the way, let me know if you every want to sell that UFO ROBO Dagnar.
johnrt
« Reply #46 on: February 13, 2015, 03:00:08 pm »
http://www.arcadeshop.de/Accessories-Carrying-Handle-black_719.html
Edit: Where are you from. I'm located in Norway so if you're from the US, the P&P would cost a fortune!
« Last Edit: February 13, 2015, 03:02:54 pm by johnrt »
« Reply #47 on: February 13, 2015, 03:22:16 pm »
Ah yes, I am in the states and on second thought I need something that doesn't show up on the reverse side anyway...
Still... Looking good so far  :cheers:
johnrt
« Reply #48 on: February 13, 2015, 03:25:54 pm »
I was thinking about the Ufo Robo Dangar...
Anyway, I'm going overseas this summer for a Route66 trip for 3 weeks. Man, I'm looking forward to this!
« Reply #49 on: February 13, 2015, 03:42:38 pm »
Route 66 eh?  Let me know if you're coming through Tulsa and need any local recommendations for food/accommodations or such.
BorgDog
« Reply #50 on: February 13, 2015, 04:15:36 pm »
Cool, lots of fun on Route 66, be sure to hit up one of these, I stayed in this one in Holbrook Arizona a few years back.:
My Projects:
johnrt
« Reply #51 on: February 13, 2015, 04:17:32 pm »
Speaking of: Is there any arcade-related sites to visit on the route?
talkgeek
« Reply #52 on: February 13, 2015, 10:32:00 pm »
Don't apologise for the detail, I'm building a "Tully" as well, and you are saving me a ton of rework  :laugh: - I wasn't planning on using battens - this build has changed my approach.
ChanceKJ
« Reply #53 on: February 14, 2015, 01:46:21 am »
The logo/typeface on that panel saw reminds me of this...
The old PMI Piranha logo from the early 2000's. I know, Serif fonts look like many other serif fonts... but thats just uncanny.
I'm planning a "Tully" style Nintendo cabaret, a "widebody" variant.  This build will come in handy for me later this/next year.
eds1275
  • Rock and Roll!
« Reply #54 on: February 14, 2015, 07:02:33 pm »
A few? Judging by those cars, it was 60 or 70!
johnrt
« Reply #55 on: February 15, 2015, 10:28:13 am »
So today I made the Nintendo-style speaker grill, and I also did the marquee slot. This Nintendo-style grill is about 25% smaller than the original one. The original speaker-grill can be found at jakobud (http://jakobud.com/plan.php?id=7). Here is how you can do this without a CNC machine, using only a router and some ingenuity! DO A TEST RUN ON SOME SCRAP PIECE OF PLYWOOD!!!
The finished result. This is the back side.
The finished result front:
And this is the router bit. It's 6 mm straight bit.
« Last Edit: February 15, 2015, 10:31:52 am by johnrt »
johnrt
So today I finished the marquee area, made the hole for the power intake and started the assembly. Battens and panels are being glued and screwed together. I also rounded the bottom corners of the side panels. I did that by using an empty roll of tape and a router and then made a template. The template was then screwed on the side panels and the panels were routed. I have also received the speaker. This fits perfect over the speaker grill. Well, here's the pics.
« Last Edit: February 21, 2015, 07:23:25 pm by johnrt »
johnrt
Re: JAMMA Multicab - A "Tully"-copy - Current status: Assembly started
« Reply #57 on: February 24, 2015, 05:44:00 pm »
Today I made the monitor "frame". And tested it with the monitor mounted both vertical and horizontal. The Lexan bezel will come a few cm higher than the monitor.
And now a question for you guys: What can I make the bezel around the monitor from? Cardboard? Foam? Do I need a bezel there at all? Any pictures out there from somebody who has done it before?
Well, here's today's pics:
jdbailey1206
« Reply #58 on: February 25, 2015, 11:09:07 am »
Dang dats purty.  How do you plan on rotating your monitor?
johnrt
« Reply #59 on: February 25, 2015, 02:15:23 pm »
Actually I don't. I just wanted the possibility to do that just in case.  :lol
If it's gonna be rotated it's has to be done manually. But that's ok.
Generic Eric
« Reply #60 on: February 25, 2015, 02:26:04 pm »
Will you paint the board the monitor is mounted to?
You'll want something to distract from the monitor and hide its mounting. Search Read about the $2 bezel.  Sometimes that is also referred to a monitor shroud I think; at least Star Wars has a cardboard monitor shroud and a crazy plastic dimensional bezel.  What its call isn't as important as covering up the monitor.
« Last Edit: February 25, 2015, 02:54:19 pm by Generic Eric »
johnrt
« Reply #61 on: February 25, 2015, 02:52:14 pm »
You'll want something to distract from the monitor and hide its mounting. Search Read about the $2 bezel.  Sometimes that is also referred to a monitor shroud I think; at least Star Wars has a cardboard monitor and a crazy plastic dimensional bezel.  What its call isn't as important as covering up the monitor.
Thank you! That was exactly what I was looking for. Painting of monitor board depends on whether I'm able to hide it using a $2 bezel! Thanks!  :applaud: :notworthy:
jdbailey1206
« Reply #62 on: February 25, 2015, 03:40:12 pm »
Its amazing what they used to use.  I know Track and Field had one and I needed to make one for my FFJR cab that was also in the DK cabs.  Its amazing what a $7 piece of mat board can do for you.
johnrt
« Reply #63 on: March 07, 2015, 06:10:42 am »
After shoveling the snow yesterday, I cut the slots for the T-molding in my Tully. (Seriously, it has never been this little snow as far as I can remember). And now I've started priming the cab. Plan is to paint the underside, mount the wheels and then do the rest of the priming/painting. As usual the first stroke of primer revealed a lot of imperfections so there will be a lot of sanding, filling, sanding, filling...
ChanceKJ
Re: A "Tully"-copy - Current status: Priming and painting
« Reply #64 on: March 07, 2015, 06:23:11 pm »
John,
...your pictures crash my iPad  :'(
johnrt
« Reply #65 on: March 07, 2015, 07:33:30 pm »
John,
Pfft... Apple...
bfauska
« Reply #66 on: March 07, 2015, 07:45:01 pm »
John,
Pfft... Apple...
But... you took them with an iPhone.
johnrt
« Reply #67 on: March 07, 2015, 07:50:21 pm »
Ohh... bummer!  :lol
johnrt
« Reply #68 on: March 08, 2015, 01:37:01 pm »
My God this is a tedious and boring job!  :banghead:
But it's slowly getting there.
ChanceKJ
« Reply #69 on: March 08, 2015, 04:05:29 pm »
<Insert Joke About Sister/Wife/Mother Here>
johnrt
« Reply #70 on: March 10, 2015, 07:06:17 pm »
Painting the back, inside, and bottom black. Rest will be Nintendo blue. I also paint the inside of the speaker grill black. I don't know why. Maybe there's a name for that disease.  :dunno
About the side panels. I can't get them as smooth as I want them to be. The plywood itself won't let me. So I say: To hell with it! It's good enough.  :lol
Re: A &quot;Tully&quot;-copy - Current status: Priming and painting
« Reply #71 on: March 10, 2015, 07:43:54 pm »
I just cut the wood on mine today.
jdbailey1206
« Reply #72 on: March 10, 2015, 08:26:43 pm »
« Reply #73 on: March 10, 2015, 08:27:27 pm »
Proof.
jdbailey1206
« Reply #74 on: March 10, 2015, 09:29:00 pm »
Psssssh.  Needs its own thread.
« Reply #75 on: March 10, 2015, 09:31:15 pm »
Threads are for suckas.
talkgeek
« Reply #76 on: March 11, 2015, 04:39:50 am »
What about just covering the sides with Vinyl vs trying to get smooth finish with paint ?  (has worked for me) - liking your progress and detail (and like Yotsuya, I started cutting out my panels for my 'Tully' on the weekend)
jdbailey1206
« Reply #77 on: March 11, 2015, 08:44:57 am »
Sucka.
Sucka.
Sucka.
Sucka.
Sucka.
What I'm getting at is I wanna see a build thread for your 'Tully'...
« Last Edit: March 11, 2015, 08:50:41 am by jdbailey1206 »
ChanceKJ
« Reply #78 on: March 11, 2015, 09:52:00 am »
+1 on the vinyl. But I can understand the frustration with sanding and painting plywood. Seriously tedious at the best of times. :)
Also agree! Yots' deserves to have one of his build threads heckled for once. ;)
jennifer
« Reply #79 on: March 11, 2015, 04:26:19 pm »
    Oh YES, And I know just the girl for the job...Now just need to set the trap. :applaud:
