Author Topic: "Thin" Joystick Recommendations Please  (Read 2513 times)
D_Harris
  • Last login:September 25, 2024, 10:06:48 pm
« on: December 24, 2014, 05:26:56 pm »
I need joystick assemblies for several projects where the joystick base has to be as thin as possible. (ie: like the Zippy). But the joystick must be long enough for the assembly to be used with a wood control panel.
Any recommendations would be appreciated.
Thanks.
Darren
My collection:Asteroids, Joust, Millipede, Ms. Pac-man, Pole Position, Robotron 2084, Star Trek, Star Wars, and 100+ PCBs. Trading/Selling:Arkanoid: R.O.D. Cocktail, Tornado spinner, Hewlett Packard 16500A Logic Analysis System with Accessories. Wanted:Mach 3 joystick. Millipede Trackball. 100° or WG4600 monitor Tube.
Re: "Thin" Joystick Recommendations Please
« Reply #1 on: December 24, 2014, 05:37:50 pm »
Groovygamegear.com has a Zippy with a long shaft for wood panels if you don't mind the increased throw.  What are you putting the stick in? Can you recess mount?
D_Harris
« Reply #2 on: December 24, 2014, 05:48:49 pm »
Thanks.
Here is one stand-alone control panel project I need the joysticks assemblies for.
Darren
« Reply #3 on: December 26, 2014, 12:33:45 pm »
Check out the wiki, for ways to mount joysticks, in the event you ever decide to go with a shorter stick in a wooden panel.
http://newwiki.arcadecontrols.com/index.php?title=FAQ#Joysticks
BorgDog
« Reply #4 on: December 26, 2014, 01:23:09 pm »
I actually bottom mounted the short shaft zippyy from GGG in 5/8" wood CP, still sticks up enough for me and works great. ymmv
My Projects:
D_Harris
« Reply #5 on: January 02, 2015, 04:36:37 pm »
I may have to create a recess and also machine a long stick down to size on my mini-lathe to achieve middle ground.
Thanks.
Darren Harris
Staten Island, New York.
D_Harris
« Reply #6 on: February 08, 2015, 09:12:08 pm »
After more thought, I decided to go with the "Under mount (support blocks)" idea, because I don't want to put mounting holes/bolts into the control panel top.
Does anyone know where I can get the necessary hardware for doing this? (I assume this will vary depending on the joystick you are using).
Thanks.
Darren
  • Last login:Today at 12:54:01 am
« Reply #7 on: February 09, 2015, 09:09:07 pm »
If you are placing an order with GGG or Ultimarc, they both carry the correct style threaded inserts for MDF.
You can make two support-bars (one for each support block) out of an aluminum or steel bar if you don't want to go with the fancy plates like EMDB did.   ;D
D_Harris
« Reply #8 on: February 10, 2015, 07:04:29 pm »
Thanks for the info on inserts.
I was thinking of using bars. I'd prefer what you call "fancy plates", but from what I can tell they would have to be custom made and I'm not set up for that.
Thanks.
Darren Harris
