Author Topic: Has any one found a way to play castle crashers with an I-pac4?  (Read 2813 times)
Locke141
  • Never grow up.
I have castle crashers playing pretty well in one player. Now I need a work arounds to make castle crashers work with 4players with my I pack.
Has anyone been able to do this? It's a long shot I know.
Sjaak
Re: Has any one found a way to play castle crashers with an I-pac4?
« Reply #1 on: December 21, 2014, 10:09:12 am »
Why is this a long shot? If you can configure the keyboard controls in the game, it should be possible.
Locke141
  • Never grow up.
« Reply #2 on: December 21, 2014, 11:21:31 am »
Unless I am missing something, You can only do keyboard config for player one.
« Last Edit: December 21, 2014, 12:41:30 pm by Locke141 »
Fursphere
  • Last login:Today at 01:11:46 pm
« Reply #3 on: December 21, 2014, 12:15:23 pm »
More specifically, players 2 - 4 only respond to X-Input gamepads (like xbox 360).   (not DirectX).
Locke141
  • Never grow up.
« Reply #4 on: December 21, 2014, 01:02:31 pm »
Yep, This is the problem.
Sjaak
« Reply #5 on: December 21, 2014, 02:01:16 pm »
I did not know that. Maybe with joy2key you could map the joysticks to keys.
SavannahLion
« Reply #6 on: December 21, 2014, 02:03:01 pm »
That's an interesting oversight given that Behemoth built a Castle Crashers cab for 2010 PAX.
I tried to find a complete build log detailing, at least, what I/O they used but could not. Perhaps a hacked 360 controller?
Locke141
  • Never grow up.
« Reply #7 on: December 21, 2014, 02:15:57 pm »
That or 4 of those expensive encoders at focus attack that show up as an xbox 306/PS3.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #8 on: December 21, 2014, 02:29:41 pm »
We will have a plug-in Xinput adaptor for the I-PAC 2 around end-Jan
SavannahLion
« Reply #9 on: December 21, 2014, 02:33:45 pm »
Forgot about those. Seeing as how I'm not really one to hack up and install consoles into cabinets.
But I digress, that's still an interesting oversight.
  • Last login:January 26, 2026, 08:08:49 am
« Reply #10 on: December 21, 2014, 04:25:51 pm »
The x360kb files from the Super Street Fighter IV thread stickied in the software forum work fine for two players.
I used it on my cab for a while with Castle Crashers before I switched to hacked xbox360 pads.
(and I'm unable to play it with the hacked xbox360 pads because the ONE button I don't have wired up is required to play the game)
I assume it would work just as well for 4 as long as you don't have any duplicate keys used.
Just add 2 more pads to the config file.
Here is the layout they used on the machine they built for shows:
Notice the combinations it shows.  Someone mentioned in another thread that you could also cycle items with the start button.
Using the workaround is actually superior to using hacked xbox360 pads.
The game doesn't allow you to change the button mapping if using real xbox360 pads.
With the x360kb config file, you can swap the buttons around however you want.
« Last Edit: December 21, 2014, 04:33:22 pm by BadMouth »
Locke141
  • Never grow up.
« Reply #11 on: December 21, 2014, 11:07:46 pm »
Thanks Bad mouth,
I will give it a try.
Fursphere
« Reply #12 on: December 22, 2014, 10:43:47 am »
They used a Playstation 3, and hacked up gamepads to hardwire them into the arcade controls.
Fursphere
« Reply #13 on: December 22, 2014, 10:45:35 am »
That's very interesting news Andy!   Is it going to be a toggle type system, where you can switch between xinput mode and keyboard inputs?
« Reply #14 on: December 22, 2014, 11:11:43 am »
THIS.  I used the x360kb.ini hack as well and it worked great!  (I had a 4 player setup with and ipac4).  Simply edit the x360kb.ini file and drop the .dll and .ini file in the same directory that Castle Crashers is in.
D
Locke141
  • Never grow up.
« Reply #15 on: December 23, 2014, 12:59:49 pm »
Andy thats amazing!  Can you give some more details?
Thanks DeLuSioNal29 I'll try it tomorrow if I have time.
« Last Edit: December 23, 2014, 01:05:44 pm by DeLuSioNal29 »
