Author Topic: Arcade games CPU clock speed and GPA clock speeds are at different speeds why?  (Read 2999 times)
vanwatson
  • Last login:January 02, 2015, 09:21:39 pm
Why are arcade CPU clock speed and GPA/TIA chips cock speeds both at a different speed rate?
Some arcade games use the same or one clock speed for the CPU, the RAM and ROM clock input signal, GPA
Other Arcade games use different clock speeds for the CPU,RAM chips , ROM chips and GPA
example:
Atari 2600
CPU clock  is 1.19MHZ
GPU is 3.58MHZ
Atati 7800
CPU clock is 1.79MHZ
GPU is 7,19MHZ
SavannahLion
Google the following
Racing the Beam
Magic quartz crystal value
Read and understand
http://www.catb.org/esr/faqs/smart-questions.html
Before you return
  • Last login:Today at 01:04:06 am
Thanks SavannahLion.   :notworthy:
Added a link to the FAQ here.
This is the most useful thing yet to come out of a vanwatson thread.   >:D
jennifer
    **Jennifer hides a laugh.... (Snicker, Snicker) :laugh2:
lilshawn
  • Last login:December 11, 2025, 11:01:31 pm
why does my GTX750ti memory run at 5.4ghz but my GPU only run at 1.15 ghz?
vanwatson
I have notice certain arcade games using the same clock frequency signal for the CPU, GPU/TIA/VIDEO ROM, ROM CHIPS, RAM CHIPS
But other arcade games using different clock frequencies signals for the CPU, GPU/TIA/VIDEO ROM, ROM CHIPS, RAM CHIPS
I don't understand why and what's the difference between using the same clock frequency compared to using different clock signals for each chip
SavannahLion
I gave you two excellent starting points as to why the T.I.A. is clocked at a very specific frequency.
The Atari 2600 programming docs have a very concise explanation as to why the 6507 runs at the frequency it does.
This kind of information will go a long way to help you understand.
Are you still posting this same crap in other forums?
vanwatson
Are you talking about this Google the following
1.) Racing the Beam
2.) Magic quartz crystal value
No
