Author Topic: Attaching Vinyl Graphics to Painted MDF?  (Read 1174 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
« on: November 07, 2014, 01:51:28 pm »
Hi Guys,
I've got my MDF bartop assembled, primed with Kilz primer, and painted with Rustoleum Satin Black.
I'm using vinyl graphics from Lucian.
Should I do anything to prep the (dry) pained MDF, or can I simply apply the graphic directly to the painted MDF?
Thanks so much!
RandyT
    • GroovyGameGear.com
Re: Attaching Vinyl Graphics to Painted MDF?
« Reply #1 on: November 07, 2014, 03:57:04 pm »
Should stick just fine.  Just make sure it is completely cured.  If you have any roller fuzz bumps, or similar, where the vinyl is going, use a sharp razor blade to shave them down.  Any debris or raised spots at all on the surface will show in the vinyl.
newoski
« Reply #2 on: November 07, 2014, 04:43:13 pm »
