Author Topic: Changing tubes on NSM CD box  (Read 3697 times)
Trickyeric
  • Last login:September 02, 2014, 01:42:48 pm
« on: August 31, 2014, 04:46:29 am »
Hi There.
I just bought a Hyperbeam CD jukebox by NSM. One of the vertical fluorescent bulbs in the door seems to have blown but I can't seems to find any way to access it. Anybody have any ideas? Ta
ed12
Re: Changing tubes on NSM CD box
« Reply #1 on: August 31, 2014, 01:30:05 pm »
is this a wall mount ?
ed
Trickyeric
« Reply #2 on: September 01, 2014, 12:33:40 pm »
Hi
Yes it is... no obvious screws/fastenings on the inside of the door?
ed12
« Reply #3 on: September 01, 2014, 01:46:55 pm »
open the door
at the bottom of the door
there is a plastic piece :cover exturision:,in the center of it is a long philps screw
remove it and the plastic piece
next u will find 4 philps screws,remove them carefuly
the bottom piece of metal will come off
u then slide the plastic cover of the corner down and out
to gain access to the lamp.
reverse order once lamp is changed
now it is a 2 person job
+ on the hinge side go  very careful as the steel bracket u are going to remove
is the lower hinge
ed
Trickyeric
« Reply #4 on: September 02, 2014, 01:42:48 pm »
Ed,
That's fantastic.... thanks so much.
Mick
ed12
« Reply #5 on: September 02, 2014, 02:15:51 pm »
yw
i will add as a rule
i take the door right off,lay it flat
and do the work
but with 2 ppl u can do it right on the box
go careful,so,steady
1 side at a time,make sure the first side is back in and tight,then move to the next
ed
