Author Topic: Made my MAME control panel..  (Read 2014 times)
winstonwaite
  • Last login:September 02, 2014, 08:52:35 pm
« on: August 31, 2014, 02:43:32 am »
Actually finished it about a month ago but with six buttons instead of eight. We use it at the office and maybe 5-10 people a day play with it. So far very happy with the IPAC and the enclosure. The wiring could be a bit cleaner but I didn't have any of the sticky anchors to tie them down so left it as is now. Also recessed the joystick bolts so it is smooth from the top. Right now it is a Seimitsu LS-32 stick with Sanwa OBSF buttons.
Louis Tully
Re: Made my MAME control panel..
« Reply #1 on: August 31, 2014, 10:40:03 am »
« Last Edit: February 12, 2015, 05:26:44 pm by Louis Tully »
winstonwaite
« Reply #2 on: August 31, 2014, 02:25:47 pm »
Took a look at some carriage bolts online and most seem to have round tops. Did find some that are flat-top but they don't have the countersink which I put in there to get the tops of the bolts flush. On top of that... I would have to find metric ones because the countersink I cut is 90 degrees but most US countersunk bolts are 82 degrees. Probably would have to hunt around online for ones that would do the trick.
lustreking
  • Last login:October 11, 2021, 08:43:06 am
  • One Louder
« Reply #3 on: September 01, 2014, 10:02:54 pm »
Nice!  What kind of enclosure is that?
winstonwaite
« Reply #4 on: September 02, 2014, 05:48:30 pm »
The enclosure is made by hammond:
http://www.hammondmfg.com/dwg16.htm#10degree
I picked part no.: 1456RL1BKBU
They also have some without the incline... http://www.hammondmfg.com/dwg20.htm (steel) and http://www.hammondmfg.com/dwg21.htm (aluminum).
I was glad I went with aluminum as it was relatively easy to cut the holes. My hole saws say they are able to cut steel but I imagine it would have been more effort.
You can find them online most easily by searching for the part numbers. Found a number of places that had it for anywhere from $38-$50.
jimmer
  • Last login:February 17, 2025, 02:48:38 pm
  • I want to play Defender like at the arcade.
« Reply #5 on: September 02, 2014, 06:08:34 pm »
I don't like the marble countertop.
On forums jimmer speaks for himself as a Defender fan, not as proprietor of www.jbgaming.co.uk  << Is that advertising or disclosure ? or both ?
winstonwaite
« Reply #6 on: September 02, 2014, 08:53:04 pm »
It is actually granite... but my wife doesn't like it either so ya got me there...
