Author Topic: My first build : Clint. Finished.  (Read 69662 times)
yamatetsu
  • Last login:Yesterday at 06:27:38 am
  • Just because.
Re: My first build : Clint. Finished.
« Reply #280 on: October 19, 2014, 10:41:13 am »
Thanks !
Looking forward to seeing your thoughts / progress on the next one  :laugh:
Oi, cut that out !  :D Strangely enough, my father wants his basement back. Why that is, after I have occupied it for a measly 10 months or so, I don't know ...
Congratulations with a brand new arcade cabinet. Very original execution. Me like!  :applaud: :applaud: :applaud: :notworthy: :notworthy: :notworthy:
 :cheers: Now stop playing on it and get yours done ! I'd like to see how the art will turn out.
Karpro
  • Last login:March 03, 2015, 09:49:37 pm
« Reply #281 on: October 19, 2014, 10:45:25 am »
Really love the finished product.  Working on ideas/plans/concepts/funding for a future build myself.  Looking back over the build process what would you do differently if anything?
yamatetsu
  • Just because.
« Reply #282 on: October 19, 2014, 12:54:42 pm »
The first and biggest thing I'd do would be to post ideas here first and do work on them after that. Not only will the people here tell you whether it looks good, will work at all and so on, it will probably lead to even better ideas. I would have saved myself a ton of work if I had done that (I had my reasons for doing it that way, but still).
For the planning part, I wouldn't plan too much ahead. I would do things in order, not worry about something two or three steps ahead. It doesn't make sense planning how to do the monitor hold while sawing the first boards. I wanted to plan everything ahead and ended up overdoing it, planning and worrying and planning and getting nothing accomplished. It also doesn't help that somewhere along the the line you will probably change your design (especially if posting here) and some of the planning ahead time will be wasted.
If I had to build the cab again, I would make it wider so I could make the CP wider. Because of the trackball and the space restrictions it causes, the P1/P2 controls sit a bit higher than intended.
If I had better tools, I would definitely do a front door with a frame for easier access. My plans for doing that without a frame didn't pan out, and I felt that I couldn't cut a perfect rectangle out of a wood panel to make the frame with just a jigsaw / sander.
The only other thing that comes to mind would be using tinted plexiglass for the marquee / monitor, as the tinted lexan scratches really easy.
Oh, one more thing : The Ultrastiks. If I had to buy them again, I would definitively order the stiffer springs also. Since they are analog sticks, they feel really loose.
AzureKnight
« Reply #283 on: October 20, 2014, 11:06:24 am »
 :applaud: - completing a very nice looking build
 :applaud: - taking a lot of tough love criticism in a very constructive way
Nice work!
yamatetsu
  • Just because.
« Reply #284 on: October 20, 2014, 07:14:57 pm »
Sometimes it's really better to swallow the 'I know everything' attitude and listen to the people who have experience. It payed off big time  :applaud:
stavros693000
  • Last login:December 14, 2022, 05:33:15 pm
  • I built my own arcade machine
« Reply #285 on: October 21, 2014, 05:27:41 am »
Beautiful
hey what happened to he-man mid orgasm  ;D your new avatar sux.
just saying bro 8)
my first build classic style upright cabinet..... MARVELOUS FIGHTER (FINISHED) http://forum.arcadecontrols.com/index.php/topic,133066.0.html
« Reply #286 on: October 21, 2014, 11:56:22 am »
Good for you, but remember, sometimes it's ok to say, "I appreciate the feedback, but I'm going to do it this way, so STFU."  >:D
« Reply #287 on: October 21, 2014, 12:08:39 pm »
That turned out great.  I love the black-on-white theme.   :applaud:
yamatetsu
  • Just because.
« Reply #288 on: October 21, 2014, 12:33:08 pm »
I would never do that.  ::)
yamatetsu
  • Just because.
« Reply #289 on: October 21, 2014, 04:16:17 pm »
I bought a photo album today to be able to show off inform people about my activities. It has a recess in front behind which you can put a photo to personalize it.
So naturally the first idea was to put a Clint picture behind it. Then I started thinking. That recess is 3mm deep, how about putting a piece of wood into it and print the pic on the wood ?
I bought a strip a balsa wood and cut it to size. It's amazing how easy this stuff is to cut, it gave me less resistance than the cardboard I used on the cab. So I didn't need any sanding, I just cut it with a knife.
So I took the leftover piece of paper you get when you peel the stickers off a sheet of printable stickers and printed the mirrored image on it. The ink does barely stick to that, so you can press it onto the piece of wood and most of the ink gets transferred. I sprayed a coat of matte clear lacquer onto it.
« Reply #290 on: October 21, 2014, 04:37:01 pm »
Dude, your "homage" to Mr. Clinton Eastwood Jr. is staring to veer into "restraining order" territory.    >:D :cheers:
yamatetsu
  • Just because.
« Reply #291 on: October 21, 2014, 04:45:43 pm »
Well, since I'm living on another continent anyway ...
« Reply #292 on: October 21, 2014, 04:51:54 pm »
  • Last login:Yesterday at 09:23:17 am
« Reply #293 on: October 21, 2014, 07:18:42 pm »
Your name wouldn't happen to be "Evelyn", would it?
yamatetsu
  • Just because.
« Reply #294 on: October 22, 2014, 08:04:08 am »
One of the greatest philosophers of our time stated :
There is no such thing as too much Clint.
So there.
« Reply #295 on: October 22, 2014, 12:43:45 pm »
Sweet! I'm a philosopher!  :woot
« Reply #296 on: October 22, 2014, 01:24:23 pm »
jaharr01
« Reply #297 on: October 24, 2014, 04:42:39 pm »
Excellent work, i like the stenciling.
