Author Topic: Yotsuya's Digital Signage Scoreboard  (Read 43240 times)
« on: August 12, 2014, 11:50:25 pm »
First off, a shoutout to Knievel  and Slippyblade for requesting this post.
I have a few dedicated games in my gameroom, as well as a MAME cab or two, and like many, I wanted to find a way to use a dedicated scoreboard. I wanted something dynamic and electronic, since my first choice, a full-size Pepsi Messageboard with Letters is hard to find and expensive around these parts.
So I wanted to do a Plan B - something digital. I looked at a few suggestions on KLOV, but none of them spoke to me, man. Then, I got an idea based on some tinkering I had done at work... I would go ahead and do my own digital signage setup. You know, those information boards you see at hotels, airports, and everywhere else? I would create and design my own.
I went out and looked for freeware digital signage packages. Most of them required you to set up your own server and stuff like that, but one service hosted everything for you, for free. I used Risevision.com because you can create an account for free and you can tweak your setup anyway you like it. The basic stuff is free - you can pay more for extra doodads and plugin, but screw that! I just wanted to display a few photos and, more importantly, high scores. Below, you can see my basic design.
The main box, under high scores, is an area that loads and scrolls a Google Spreadsheet. I installed Chrome and Google Drive so I have access to the spreadsheet on my phone (more on that later). On the right, I have an area that scrolls cabinets and flyers that I host on Picasa, and under that is a spot that scrolls screenshots and arcade photos. Upper right is the time and date. You can make your layout as simple or as complicated as you want.
I had a spare 19 inch monitor that I had lying around, so I ended up buying a monitor mount arm for it. I also purchased a flush monitor mount, because I wanted to mount the controller right next to it. I got a dirt-cheap Dell OptiPlex 160 on eBay for like $40 or so. The ONLY thing this unit would be for is controlling the scoreboard, so it didn't need a lot of processing power. I set up the machine to run Windows 7, and once it was ready, I linked it to the digital signage account, so any signage I made or changes or updates would automatically be pushed out to it. I bought a cheap USB Wi-Fi connector for it, because I wanted all updates to be sent wirelessly.
I installed the monitor on the wall with no issues, and used the flush mount to put the PC directly behind it.
When you push the monitor into position, it effectively hides the computer.
So all I do is push the powerbutton on the OptiPlex. The machine automatically boots into Windows 7, then right into Chrome and the Digital Signage software. The Google Doc loads and the scores scroll up. I can open the spreadsheet on either my phone or my PC and make changes to the high scores if need be. It saves it and refreshes dynamically, so the new score shows up pretty much instantly. I can upload photos to my Picasa and they'll show up after the RSS feed refreshes. Also, there's a red scrolling ticker at the bottom I use for fun messages, but I bet you could stick sports scores or something else there.
Well, there's my scoreboard. It's pretty much exactly what I envisioned for it when I decided I wanted a digital one. If you have any questions, feel free to ask.  :cheers:
« Last Edit: August 13, 2014, 10:35:26 am by yotsuya »
crtrrss
Re: Yotsuya's Digital Signage Scoreboard
« Reply #1 on: August 13, 2014, 12:04:28 am »
Impressive. Maybe you could make the document public and have a little high score challenge among the forum members. :)
« Reply #2 on: August 13, 2014, 12:06:13 am »
That's not a bad idea. If anyone else builds one of these, we'll do a BYOAC Scoreboard Network!  :cheers:
crtrrss
« Reply #3 on: August 13, 2014, 12:08:58 am »
Well, I had a ton of spare desktops that are obsolete for almost anything else and LCDs anyways. I might as well.
« Reply #4 on: August 13, 2014, 12:09:34 am »
Right after I posted that, I went ahead and tweaked the scoreboard to list local scores and BYOAC Scoreboard Network Scores. So we'll see!
crtrrss
« Reply #5 on: August 13, 2014, 12:12:14 am »
Heck, maybe this'll be a sticky for the official scoreboard someday. Then y'all can see how horrible I am at arcade games!
crtrrss
« Reply #6 on: August 13, 2014, 12:57:49 am »
Do you know the claim ID? With that, other people can access the form and see the scoreboard. You might also have to do something with the google document containing the actual scores too to make other people edit what's on it
« Reply #7 on: August 13, 2014, 01:28:31 am »
I'll open it up in a few weeks. If people are interested in sharing scores via a Google Spreadsheet, let me know.
« Reply #8 on: August 13, 2014, 09:31:13 am »
When you push the monitor into position, it effectively hides the monitor.
« Reply #9 on: August 13, 2014, 10:35:45 am »
Fix't. Cabsole!  ;D
Knievel
    • Knievel Kustoms
« Reply #10 on: August 13, 2014, 10:51:52 am »
Awesome idea, thanks for sharing it. Just what I was looking for.
Heading to the lake for a few days but I'll tackle it this weekend.
Everything on the digital signage end looks easy enough thanks to your explanation. Did you start with a specific template to do your setup?
Also could explain the Google spreadsheet more, or possibly share yours? I have no idea what that is.
rablack97
« Reply #11 on: August 13, 2014, 10:53:16 am »
wow very innovative man.......nice work sir... :applaud: :applaud: :applaud:
rawbe
  • Last login:June 17, 2025, 05:54:46 pm
« Reply #12 on: August 13, 2014, 11:14:15 am »
This is……AWESOME!
« Reply #13 on: August 13, 2014, 11:25:53 am »
Nice work Yotsuya!  I'm going to mess with this down the road!
D
Generic Eric
« Reply #14 on: August 13, 2014, 11:49:03 am »
This is neat.
« Reply #15 on: August 13, 2014, 11:56:39 am »
Thanks, guys! Glad to finally share it.
Here's a link to a BYOAC Scoreboard Network spreadsheet:
https://docs.google.com/spreadsheets/d/1X9AmOYta-NiB2VhOOsxpAJd1ZVi5ohflTMpU7IcbYZk/edit#gid=0
Any of you all can edit it. Add games, change scores. You're all on the honor system.
I'll integrate it into my setup.
To answer the template question, I started with a built-in one to learn how it works, then I did my own from scratch. If you go the scratch route, you just need to play with it to get a feel for what works. I just keep it to one screen, but you can actually make multiple screens that it transitions to, almost like a super-fancy PowerPoint. I thought about doing one page of scores, one of photos, one of game trivia, etc but in the end I decided to keep it simple. You can make it as simple or as complex as you want.
I'll shoot a video and post it tonight so you can see how it looks.
« Reply #16 on: August 13, 2014, 11:59:38 am »
If I actually kept one of my MAME creations, I would LOVE to have one of these. This is pure genius!
Generic Eric
« Reply #17 on: August 13, 2014, 12:02:02 pm »
Are the lines below Burger Time visible?  Does it scroll?
jugger18
  • Last login:February 25, 2020, 09:58:30 am
  • Time to make a bitchen man cave
« Reply #18 on: August 13, 2014, 12:03:49 pm »
All I know is that PSC is dominating!
« Reply #19 on: August 13, 2014, 12:09:44 pm »
On the spreadsheet I posted, you see three columns:
First is game name, second is score, third is initials. It shows up exactly like that on the signage, so there are no column headers. You can simply change a score or initial or add a game, and it automatically saves it. The scoreboard, once refreshed, shows the new scores.
BTW, what's cool is that you can add more than one computer to the setup. So if you had 2 or 3 TVs and PCs in your game room, you could send the same content to each, or you could have one running a scoreboard, the other running flyers, etc. It's really versatile.
I bet that dude's  a ---smurfing--- cheater.  :P
« Reply #20 on: August 13, 2014, 12:10:23 pm »
Yes, it scrolls. Once it gets to the end of the sheet, it loops back over and over again.
« Reply #21 on: August 13, 2014, 12:15:59 pm »
This is radical.  :applaud:
« Reply #22 on: August 13, 2014, 12:28:08 pm »
Thanks, LC.
If anyone is interested in trying this, feel free to shoot me a PM if you need help. You can also use widescreen monitors - I just happened to have a space 4:3 lying around. You can customize the layout to fit your size.
As far as the photos go, I have a folder on my desktop called "Arcade Pics". In that are two folders "Cabinets" and "Screenshots". If I want to add photos to the layout, I just drag them in there and open Picasa. It scans the folders at startup and uploads new photos to the web. The RSS feed gets updated, and they show up on my screen.
« Reply #23 on: August 13, 2014, 01:10:24 pm »
Dag yo.  8)
I am nowhere near having a scoreboard setup for my gameroom, but I think this solution is awesome. :applaud:
« Reply #24 on: August 13, 2014, 01:31:19 pm »
I'm not at the level where I'm paying people to come beat my high scores, but they're welcome to come by and try!
« Reply #25 on: August 13, 2014, 01:37:07 pm »
Gives me a great idea for a kick starter...... I think I'll need about..... 8 grand.
« Reply #26 on: August 13, 2014, 01:39:55 pm »
I say we rent this ---maternal-smurf--- for a BYOAC party!
http://newyork.craigslist.org/mnh/bfs/4608302628.html%3C/p%3E
« Reply #27 on: August 13, 2014, 01:45:08 pm »
Iunno, the TV looks like it was hung by the geek squad, and man, that carpet is terrible looking.
yamatetsu
  • Last login:Today at 01:11:07 pm
  • Just because.
« Reply #28 on: August 13, 2014, 02:19:19 pm »
That might be because it actually is a wall.
« Reply #29 on: August 13, 2014, 02:31:25 pm »
I say we rent this ---maternal-saint's minion--- for a BYOAC party!
Would we lose our deposit if we shat on the rug and swiped the hard drive off of the fix it felix?
spoot
  • Destroyer of electronics
« Reply #30 on: August 13, 2014, 03:19:29 pm »
How about a kickstarter campaign for paying lawyers to go after him for infringement?   ;D
Edit: The craigstlist rental thingie.
« Last Edit: August 13, 2014, 04:10:18 pm by spoot »
« Reply #31 on: August 13, 2014, 03:32:45 pm »
I got a tenner on it
« Reply #32 on: August 13, 2014, 04:29:45 pm »
Galaga (Fast)   1045110   LEW
DAAAAAAAAAAAAAAAAAMMMMNNNNN.... got my work cut out for me...
« Reply #33 on: August 13, 2014, 04:34:48 pm »
Generic Eric
« Reply #34 on: August 13, 2014, 04:39:59 pm »
null
« Last Edit: August 13, 2014, 05:20:39 pm by Generic Eric »
spoot
« Reply #35 on: August 13, 2014, 05:33:02 pm »
That also had what...five notes?
HaRuMaN, your avatar seems very appropriate at times.   :D
Generic Eric
« Reply #36 on: August 13, 2014, 09:06:13 pm »
Still working on it, but here is where I am at.
« Last Edit: August 13, 2014, 10:44:47 pm by Generic Eric »
« Reply #37 on: August 13, 2014, 09:32:53 pm »
Nice! Good work so far, Eric!
Generic Eric
« Reply #38 on: August 13, 2014, 09:37:15 pm »
Shazzle!
I modified the post before I saw you quoted me.
Generic Eric
« Reply #39 on: August 13, 2014, 10:59:17 pm »
In case anyone is wondering, it automagically puts the spreadsheet in alphabetical order.  I'm not staying up any later adding the BYOAC high score comps. But the first 100 are left.
