Author Topic: Moving jukebox questions!  (Read 6357 times)
du24pont24
  • Last login:April 30, 2017, 12:49:56 pm
  • I have a CD100a Rowe Juke box.
« on: July 22, 2014, 05:53:02 pm »
I am moving a Rowe CD100a juke, and I don't know if there is a proper way of doing it???   I thought there is a way to lock the player so it is not bouncing on the springs???  Do I need to take all the cd's out??????
Thanks for any help!!!
Derek
Derek
South Bend, IN, USA
ed12
Re: Moving jukebox questions!
« Reply #1 on: July 22, 2014, 06:16:24 pm »
remove all cd's
and the carossal should have lock down bolt's
ed
du24pont24
« Reply #2 on: July 27, 2014, 08:35:36 pm »
I don't see any bolts, but there is two stamped brackets.   (loose)     But where do they go????
Derek
Derek
South Bend, IN, USA
ed12
« Reply #3 on: July 27, 2014, 09:04:52 pm »
i would sub to this list
or phono land..either will have your proper answer
>[Jukebox-list] Rowe CD100 Transportation
Ron Rich ronnnrich at yahoo.com
Tue Oct 20 08:33:56 PDT 2009
    Previous message: [Jukebox-list] Rowe CD100 Transportation
    Next message: [Jukebox-list] Wurlitzer 2700 relay ratcheting
    Messages sorted by: [ date ] [ thread ] [ subject ] [ author ]
This model does NOT use the "lockdown brackets"---they went "back" to bolts--again. Ron Rich
--- On Mon, 10/19/09, Paul Howlett <pinballpauls at gmail.com> wrote:
Subject: Re: [Jukebox-list] Rowe CD100 Transportation
To: "Jukebox mailing list" <jukebox-list at lists.netlojix.com>
Date: Monday, October 19, 2009, 9:51 PM
Hopefully, the mech lock-down brackets are in the machine.  They hold the
mech tight against the floor of the machine. Then you can lay it down after
removing the CD's and securing the CD clamp.
On Mon, Oct 19, 2009 at 3:45 PM, Dan Penoff <dpenoff at mac.com> wrote:
> Looks like my holdout guy has finally tossed in the towel... I'm going to
> look at a complete CD100I tonight to see if it's worthy of being added to
> the collection.
> One question for those familiar with these models - can they be transported
> on their backs, or do they need to be upright?  If I can lay it down, are
> there parts that need to be secured?  My only means of moving one around
> upright is on a trailer, and I hate the thought of doing so, as it will get
> bounced around a lot.
> Thanks,
> Dan
> _______________________________________________
> Jukebox-list mailing list
> Jukebox-list at lists.netlojix.com
> http://lists.netlojix.com/mailman/listinfo/jukebox-list
    Previous message: [Jukebox-list] Rowe CD100 Transportation <
or if shawn happens across this thread ?
ed
