Author Topic: mounting vertically, or rotating monitors question  (Read 1741 times)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« on: December 07, 2003, 10:05:27 pm »
I am looking to use a 21" Viewsonic monitor for my cab.  I am seroiusly considering making it rotate, but I have a couple of questions:
1. I plan on removing the monitor from the case and supporting it by the 4 holes at each corner of the tube and by the bottom (where most of the electronics are).  But when I rotate it, the bottom now becomes the side.  Is this an issue?  Will I need additional support?
2. I don't really have a second question.  Well I did a minute ago, but I think I just figured it out.  I'll share, just in case somebody has a comment...  I was concerned that if I make the monitor rotate *too* freely, then when I rotated it to the vertical position it would be unbalanced and it would tend to settle to the horizontal position.  Then I figured that a majority of the weight is in the tube (correct me where I go wrong) so it may be ok.  And if it is off slightly, a few counterweights on the opposite side should balance it nicely.
If you need any clarification, let me know and I will try to draw some pics.
Thanks for your help.
jonathan
telengard
  • Last login:October 21, 2025, 02:12:46 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
Re:mounting vertically, or rotating monitors question
« Reply #1 on: December 08, 2003, 12:31:12 am »
jonathan
Hi there,
I have a rotating monitor and I must say, it's a lot of work but well worth it!
I had no issues w/ the bottom/side.  As long as it's secure and it's weight is held up by something.  The weight in mine is distributed in the horiz and vert.  I pretty much followed
an existing way to rotate with a few small changes.
As for your second question, the weight should provide plenty of inertia so that it doesn't move etc.  Mine never moves while playing etc.
Have fun!
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
