Author Topic: Use for Gauntlet Legends  (Read 2442 times)
JCHusky77
  • Last login:December 16, 2014, 11:16:01 am
« on: May 23, 2014, 10:58:54 am »
Hello all!
My friend has a Gauntlet Legends arcade...just sitting in his garage because its too heavy to get up his stairs. The game is in great shape and works great.
Is there a way to turn it into a MAME cabinet while still using the PCB inside? Like is there a switcher that will go from PCB to a PC setup while still using all controls?
I know its a 4 player set up with 3 buttons each. Is there a website that will filter what other games are 2-4 players that only need 2-3 buttons?
Is it worth it?? lol
Thanks for all the input!
DaveMMR
Re: Use for Gauntlet Legends
« Reply #1 on: May 23, 2014, 12:02:34 pm »
You can get one of these:
http://www.ultimarc.com/jpac.html
and then one of these:
http://www.jammaboards.com/store/2-in-1-multijamma-switcher-pcb-gbs-8118-gbs-8118.html
And I think it's worth it - the amount of games that require more than three buttons are a minority among the overall total of available games (SFII and it's ilk, many, but not all Neo Geos, Mortal Kombat, Narc, etc.)  MAWS is no-more but check out Mawler for it's recreation:
http://forum.arcadecontrols.com/index.php/topic,136193.0.html
« Last Edit: May 23, 2014, 12:05:45 pm by DaveMMR »
fytr
  • Last login:May 07, 2021, 10:39:46 am
« Reply #2 on: May 23, 2014, 01:33:46 pm »
Hi,
You will have problems getting the 4 analog joysticks on the Gauntlet Legends cabinet to work with mame. There used to be boards available to support this but AFAIK these are no longer available.
I converted mine to a Mame cabinet about 4 years ago and ended replacing the analog joysticks with 360s from Ultimarc for this reason.
It's a beauty cabinet though and worth it if you have the room!
  • Last login:Yesterday at 08:07:20 pm
« Reply #3 on: May 23, 2014, 01:34:32 pm »
Rip out the analog sticks and replace them with 8-ways.  Gauntlet plays fine that way.
JCHusky77
« Reply #4 on: May 28, 2014, 10:02:05 am »
Ok, I may do that. I need to pry it off my buddy first!
When you guys use a PC for a MAME, did you also make your MAME a NAS? For instance, if I want to stream music off of it, can it still occur while a game is being played?
