Author Topic: Who has done a removeable CP?  (Read 1702 times)
chrisindfw
  • Last login:May 09, 2020, 05:57:34 pm
  • I drank what?
« on: December 05, 2003, 03:55:34 pm »
I have seen people thay say they have a removeable control panel. Yet, I have not seen one and the luck people have had.
I am interested in building a cab with a removeable control panel and would like some examples and advice.
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
Re:Who has done a removeable CP?
« Reply #1 on: December 05, 2003, 05:16:10 pm »
I modeled my removable panels on the famous Roswell cab.  You can see it in the Examples section of the site.
http://www.arcadecontrols.com/arcade_roswell.html
A link to my site is under my avatar on the left.
buddhavelvet
  • Last login:July 28, 2010, 09:30:27 am
  • 2084
« Reply #2 on: December 05, 2003, 06:04:26 pm »
depressd
  • Last login:April 04, 2019, 04:29:33 am
« Reply #3 on: December 05, 2003, 06:41:04 pm »
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #4 on: December 05, 2003, 10:02:12 pm »
My arcade machine...
http://www.bkgrafix.net/
(click on Arcade on left)
The panel isn't removable as in you pull a lever and it pops off and you stick another in, but if I made another panel the same shape I could easily disconnect four Molex connectors, and this one lifts off and another can be put in its place.  It's held on mostly by its weight, and a little friction.  (stays on pretty well so far.)  It's more like "upgradeable" than "swappable".
If you want to make a removable panel, I suggest finding a plug type that has lots and lots of pins on it, like an IDE cable or something.  The large-type Molex plugs are a bit difficult to pull apart.  Maybe the small-type Molexes are easier, I haven't tried them.
« Last Edit: December 05, 2003, 10:04:45 pm by grafixmonkey »
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #5 on: December 06, 2003, 01:32:35 am »
Mine is removable to.  Click WWW link.
eightbit
  • My cab is never done...
« Reply #6 on: December 07, 2003, 12:30:12 am »
ButeLegz
  • Last login:December 10, 2003, 06:23:38 pm
  • Feldman knows best.
    • www
« Reply #7 on: December 07, 2003, 04:50:32 am »
I made detachable, hook-on control panels for my cocktail cab so I can play 2 player fighters etc. (that for obvious reasons need to have both player one & two on the same side) as well as the traditional 2 player cocktail games like Galaga that alternate between player 1 & 2 via screen flipping. It's not quite finished but me thinks it'll work a treat. Check it out...
http://homepages.ihug.com.au/~simons3/Controls.htm
telengard
  • Last login:September 13, 2025, 04:34:35 pm
  • Yeah, it's a classic! 21+ on BYOAC and still goin
    • S T U R C A D E
« Reply #8 on: December 07, 2003, 03:27:41 pm »
If you have a lot of time on your hands you could go one step further and do modular panels like I did.  I had removable ones previous to that and like the modular approach much better.
S T U R C A D E     M.A.M.E. Cabinet
http://www.briansturk.com/mame.html
paigeoliver
  • Awesome face!
« Reply #9 on: December 08, 2003, 07:55:53 am »
I always PLAN on adding swabbable control panels to my cabinets (even went so far as to make some panels for one cab that I never got around to maming), but I haven't actually done it yet.
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #10 on: December 08, 2003, 02:03:47 pm »
I like having swappables.
currently:
1 defender
1 generic 2-player with 3 buttons each + trackball
1 Mortal Kombat 4
I have the parts for a Tron/spinner panel... but have been playing with other toys lately.
I used rs-232 cables to facilitate the swapping.
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
grafixmonkey
« Reply #11 on: December 09, 2003, 04:14:42 am »
Just a note, you can buy PCI socket plugs, and you can buy PCI cards that just have the edge connector and some solder points - that would provide you with lots of contacts and it'd be easy to insert and remove.  It's one option for swappables anyway.  If you measured pretty accurately, you could even just slide the panel into an opening and the card would automatically go into the slot and connect all your controls to the ipac.
